Question about Black & Decker 5.2 AMP 14-Inch Grass Hog Trimmer/Edger #GH700
Motor turns but trimmer doesn't .there seems to be squeal coming from the lower part of the machine.
Why is my Hobart dishwasher making a high pitched squeal?
Usually when calls come in with this type of complaint, the technicians always have to pull out the dishwasher from its installation and disassemble the lower spray arm section to check for debris in the pump and motor or the sump depending on which brand and model you have. It usually turns out to be quite a job and routinely brings in a labor cost of at least $125.00. If your going to try and diagnose this your self you will want help. Most manufacturers have a technical assistane line. You should have an 800 number on the model serial tag of your dishwasher that you can call and see it they can get you to that department. You can also try sites like repairclinic.com....Good luck
Dec 15, 2014 | Hobart Dishwashers
Lg waveforce washer makes grinding squeeking noise drum hard to trun.
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
The tub bearing also appears to be part of the problem.
Aug 22, 2014 | LG WT5170V 4.7 cu ft High Efficiency Top...
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Neuton cordless hedge trimmer sounds "rattly" and the blade doesn't go back and forth. the battery is good. could it be the motor?
Sounds like a problem I had, and it was the primary gear on the motor was stripped. So far no luck at finding the gear, but to replace the trimmer without battery would probably be cheaper.
Feb 19, 2012 | Nike Neuton CE 52 14Inch 24Volt Cordless...
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
My Zanussi Aquacycle 1050 doesn't seem to be spinning, what could be the problem and what would be the solution.
Hi **** from retired Englishman in SW France,
'......doesn't seem to be spinning'.
Are you saying that the clothes are coming out wet or is it not physically moving/spinning?
Just in case, although no promises, try the following!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Washing Machines
Wahser makes loud noise trying to stop spin cycle It seemed to spin ok and agitate but made terrible noise when trying to stop
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing. but more than likely its the brakes, or the belt itself ,, a solinoid signals the machine to stop which in turn applies brakes just like a car only smaller, when these wear they tend to do the same as a car and squeal , its just an indication your machine is up for some maintenance,
Jul 25, 2011 | Washing Machines
Belt is squealing agitater not turning
The belt needs tightening -- it's slipping, causing the squealing and preventing it from turning the agitator.
Unplug machine, remove back to access motor. You'l see adjusting bolt(s) -- loosen them -- pry motor to get tension on belt -- while holding motor in place tighten adjusting bolt(s).
More info, let me know.
Charlie
Sep 01, 2009 | Maytag Washing Machines
Dictaphone 2710 noise problem
This squealing noise is caused by the capstan motor. The bearings have dried up and it's metal on metal - causing an awful squealing noise. As soon as you put in a cassette, the motor begins to spin - causing the squealing noise.
Aug 11, 2008 | Dictaphone Audio Players & Recorders
Black & Decker 5.2 AMP 14-Inch Grass Hog Trimmer/Edger #GH700 Logo
261 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
