Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My image 2000 is saying FLO and will not come on i just bought this used and i dont have a manual ,i am assuming the filter is dirty but i dont know where it is located ,thanks shane ps it worked fine for about 24hrs
    Problem Solver:
  • 8 Answers
Definitely need to clean the filter. If that doesn't work you may need a new pressure switch.
Posted on Sep 25, 2009
What does FLO indicate?
Indicates inadequate flo across the heater. Normally indicates a dirty filter. Remove filter and see if error code goes away.
Jul 12, 2016 | Pool & Spa
What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
Jan 17, 2015 | Pool & Spa
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Raybak pool heater says flo and will not run
dirty filter or pressure switch or loose wires to pressure switch or plugged inlet to pressure switch
Oct 05, 2013 | Jandy LXI 300 PROPANE POOL HEATER -
Parts
That would likely be FLO... Check to be sure you have good strong water flo at the jets returning to the pool or spa... Check your filter to be sure you have cleaned it properly. A dirty filter will reduce flo and result in the heater not working if the water flow is too low.
There unfortunately a large number of factors to be able to provide much more information without a detailed description of your equipment, the layout, valve positions and condition of the equipment.
Aug 12, 2012 | Jandy Pool & Spa
Use of pool vacuum
Try consulting the owners manual for these pool filters for more info. I can tell you that you need to have your valve set to rinse for normal vaccuming and waste for heavily soiled pools. Hope this helps.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 04, 2010 | Hayward SAND FILTER, PRO SERIES
I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Oct 29, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I just bought this vacuum at a second hand store. My girlfriend told me to grab it as it such a quailty product. How ever I can't find a model number or anything else. I need a manual please. Does it take...
I suggest you google what you know. I dont think anyone here can suggest where you can get a manual for a machine you dont even know the name of.
You ask about a bag ... I dont know ... is there one in it now? You ask about a filter, does it look washable?
This 'quality product' is no value if you cant use it, cant get parts for it.
Donate it to the second hand store.
Im sorry to give you this kind of answer.
a
Oct 05, 2009 | Vacuums
Camera not detected by computer
Remove the Canon software and put it back in the box Assuming you are using Windows ME/2000/XP/Vista the computer will find the camera all for its self- assuming the camera is switched on and set to the image upload mode[check your manual]
Aug 06, 2007 | Canon PowerShot A95 Digital Camera
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
123 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
