Question about RTO Mow Aerator Riding Lawn Mower Tire Brackets
Right front tire of riding lawn mower is bent in, not flat. How do I fix this?
  • 40 Answers
As long as teh bead selas and the tire holds air, i'd leave it. Othewise, go to northern tool and equipment or fleetfarm and find a replacment rim. there all pretty standard widths and bolt patterns. Should be too expensive either.
Posted on Sep 17, 2009
Mower deck adjustment mtd 13538
Are all the rods that hold the deck on all the same length. Has any been replaced with the wrong ones. Did this machine hit something that things were bent an out of shape.
Are your tires blown up where they should be? Soft tires will do that.
Dec 06, 2016 | Mtd Garden
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
My mtd riding guarden tractor has a left and a right drag link the front wheels go in opposit directions how to fix them
sounds like one or both spindles are bent or came unwelded
check the spindles over carefully
check rods going to them may also gotten bent
Sep 10, 2015 | Mtd Garden
My riding mower front tires are hard to turn cause they want to point in different directions and not straight. what could cause this
1) The tie rod between the front wheels is bent or the adjuster nut has come loose.
2) The plastic wheel bearings have gone to sh*t on either or both sides
3) The steering knuckles were never greased and their bushings are shot to sh*t.
4) The front tires have come off the rims
5) The front axle beam has been bent
Find a small engine repair shop in the yellow pages and have a person with know how put his eyes and hands on it, you will know within a few minutes what is wrong.
Sep 22, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Can you use Fix a flat to repair a flat tire on the Cub Cadet LTX 1042
If it's a simple puncture, "Fix-a -Flat" or another product called "Slime" might work for you. I believe Walmarts sells both.
Hope this helps... Good luck!
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Huskee LT 42 Lawn Tractor's mower blades drag on the left side cutting into the dirt.
check blade to see if it is bent or perhaps the blade spindle is bent are the tires properly inflated on a flat surface ceck to see if the deck is level good luck
Sep 07, 2009 | Mtd Garden
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Front wheels of our riding lawn mower
Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
Sep 18, 2008 | Garden
RTO Mow Aerator Riding Lawn Mower Tire Brackets  Logo
248 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
