Question about Sansui VRDVD4005 DVD Player/VCR
Vrdvd400a dvd/vcr combo
Parental code locked by Foster child. need to unlock and reset. Please help
2 Suggested Answers
SOURCE: parental control feature
if you can get to the operations menu page, after selecting on or off next to parental lock, press stop button four times then press enter this should clear the security code. press the number keys to create a new code press enter.
Posted on Jan 09, 2008
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Have Sansui @0" tv/dvd/vcr combo that my son locked the parentals control
yes..but you'll need to have a service professional do a firmware reset on this unless you can gain access through the service and support menu..
is this a new form of Child Protection and control?
Mar 20, 2008 | Sansui DTV2760 27" TV
Child block
I understand that you wish to remove the child lock(Parental Lock) on the player. Please follow the below steps to unlock the player from child lock.
Thanks for understanding. Please let me know if you require any further assistance/clarifications.
Jun 17, 2011 | Sony RDR-VX500 DVD Recorder/VCR
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
Aug 07, 2010 | GoVideo DV1140 DVD Player / VCR Combo
PLEASE HELP, PARENTAL LOCK CODE ESA DVD/VCR COMBO UNIT
this is a new thing on dvds. must reset.
Feb 25, 2008 | Televison & Video
Bush Video Dvd combo Dvrhs02 Lock Code
Turn the unit on then press the 'vcr/dvd' and 'disc menu' buttons on the unit together and hold down until the unit reboots
Jan 03, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Parental control feature
Dec 08, 2007 | Sansui VRDVD4005 DVD Player/VCR
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
PHILIPS DVP721 COMBO
You have pressed C.LOCK (child lock) which turns off the control buttons on the front of the unit Press C.LOCK again to switch off the child lock. OFF will appear in the display window. See: http://www.p4c.philips.com/files/d/dvp721vr_05/dvp721vr_05_dfu_eng.pdf
Mar 05, 2007 | Philips DVP721VR DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
