Question about Garmin StreetPilot C330 GPS Receiver
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem? Do I need to replace the battery? I may not be charging it up properly. The message "Charging battery" Press the power key to turn on." comes up on my screen when I plug it into the computer USB. I have been pressing the power key, making the unit come on. then the unit stays on while it is charging up. Should I be leaving the unit off until it is charged up? My problem is the charge is not lasting for any length of time.
  • 491 Answers
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Posted on Sep 06, 2009
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen says low battery, then goes blank. can I get a new battery?
Yes, you can replace the battery. Please view video at link; http://www.videojug.com/film/how-to-replace-your-garmin-street-pilot-c330-battery-2
And also see link to purchase battery.
http://www.newpower99.com/Battery_for_Garmin_StreetPilot_c330_p/garmin%20streetpilot%20c330.htm
Please let me know if it helps.
Thanks
Apr 26, 2010 | Garmin StreetPilot C330 GPS Receiver
Our Garmin Street Pilot will not charge. Do the
The batteries DO die after a time. They are not designed to be replaced by the user. If you believe your battery has died, you should contact Garmin.
Jan 05, 2010 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
How do I change the battery in a Garmin Street Pilot C330
Sep 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
397 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
