How does the feed on top of the printer work? Mine will not feed the paper. Canon All-in-one MP830 Printer
  • 106 Answers
It works just as and when a paper is taken to print it adjust a lock at the size of currently using paper then after it is used for print it takes the next paper of same size
Posted on Sep 06, 2009
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 has error code 6B00 after paper jam
6B00 is Paper feed position error.Look for any pieces of paper in sheet feeder.
Dec 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 fault code 6B10
Try to change paper size in the offending tray.
Jun 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer keeps showing an error 6A00 on LCD screen
There is one solution you can reinstall software of printer
May 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I run a Mac OSX Leopard My Canon MP830 seems to be having a paper feed problem. I also get the Error 5010. This happened right after using the scanner. It starts to work ok, but then a noisy clicking...
Is the message 5100. Paper jam? This indicates that the printer head carrier is being interferred with. Open the cover and check the slide bar and the paper path to see if there is something obstructing movement. If the drive belt has slipped it needs to be reseated.
Apr 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The scanner/fax on our canon mp830 isn't feeding the paper through? any help???
Try these solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper tray empty, or paper jam at back
Hello, I had same problem with my Pixma 600, when you lift the control panel flap to turn on the printer just below the on off button ther's a small icon of the printer with a green led at the top and one at the bottom. Press the button to the right to change either top paper feed to bottom tray feed or vice versa.Then try again, you may need to load paper in tray at bottom/front on printer.
Cheer's
Paul 'W'
Onyer~EDson(:0)~[><
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper feeder not working
Are you sure the correct paper feed has the paper and the machine knows to pull from that feed?
There are two paper feeds on this unit.. one in the tray down front and one in the rear top. There is a switch on the left hand side of the front panel and whichever feed area you want to use should be GREEN...
Let me know.. we'll go from there if that's not it.
MaggieB
Feb 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Sheet feeder isn't working
which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
Jun 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
k24674
jasbo
jasbo
