Question about Sansui VRDVD4005 DVD Player/VCR
Parental control feature
Foster child locked unit out for "g" only cannot unlock. Is ther a master code to reset unit to default status?
If you can get to the operations menu page, after selecting on or off next to parental lock, press stop button four times then press enter this should clear the security code. press the number keys to create a new code press enter.
Posted on Jan 09, 2008
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
Master password
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Child lock on in LC-T32HV
Feb 26, 2013 | Televison & Video
White screen with enter a 4 digit control pin and press select??? picture on both sides of white re fine!
It appears to be your parental control feature, or lock function. Try the codes 3001 or 1234 to reset the lock feature.
Press: Menu>Features>Parental Control(Child Lock)>Select,
then enter the code.
Nov 02, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
CHILD LOCK RESET
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Aug 31, 2012 | Samsung UA60D6600 60in. LED TV
How to unlock childs security?
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Instructions
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu
Jun 28, 2012 | Sansui DTV3200 32" TV
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Parental controls
wuts the model # on the television
Nov 03, 2007 | Insignia IS 20" TV040919 TV
Sansui VRDVD4005 DVD Player/VCR Logo
143 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
