Hi i have a samsung r720 and everytime i have a problem with program or file it goes into protection mode and shuts itself down,can i turn this function off as i also have a R60 and that does not do that,cheers Chris
  • chrismurray3 Sep 09, 2009
    Do you know how i can do it ,cheers as my other laptop just comes up with a message saying program not responding then gives you opptions on what you want to do
  • 615 Answers
Yes you can but make suer that is what you need
Posted on Sep 08, 2009
  • Norman Al-Anbar Sep 09, 2009
    I contactede Samsung and they stated that you need to run the following to help with the issue and aslo they are getting new update tro fix this problem soon.
    . You can use Samsung Recovery Solution to backup and restore your system. To find out how to make a backup, or recovery, please refer to the Samsung Recovery Solution help file attached to this document.
    2. If you are unable to use Samsung Recovery Solution to to fix your problem, please search for "Reinstall Windows Vista from Recovery Media" to reinstall the Operating System
    To get copy of the manual if you lost yours you can get copy at:
    http://www.samsung.com/uk/support/downlo...
Can't open,in protect mode
Hi:
First disconnect all speakers from the unit and then try turning the unit on too see if it still goes to protect mode. Protect mode is a shut down feature that shuts down the unit because of a shorted speaker or speaker wires are touching each other. If the unit does not shut down after disconnecting all speakers then reconnect them one at a time while turing the unit on after each conncection until you find the shorted speaker. If it shuts down with no speakers attached to it then you have a internal problem with the amplifier section, probably a shorted output transistor in the Amp circuit or preamp circuit.
Jul 08, 2011 | Yamaha Audio Players & Recorders
Our Samsung HT-C6900W Theater System shut off yesterday and then said it was in protect mode, now we cant get it turn on. This system is only 3 months old. Can you help?
The problem is with the amplifier overheating so the system shuts down to protect itself.
Make sure the ventilation fan is not block or obstructed.
If this is OK then contact your supplier with the equipments warranty.
May 01, 2011 | Samsung HT-C6900W Theater System
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
System turns off and flashes "Protect"
Hi, you have a short somewhere along your speaker wire. When the receiver goes into protection mode, it shuts itself down so you don`t blow your on-board audio amp.
If you see protect come up on your Receiver, you have got a short somewhere. What`s happening is your receiver is sensing an overload somewhere in your system and if it does not go into protection mode and shut down , there will be permanent damage done.
You will need to check the speaker wire if it is not bridging somewhere or sometime else..
Have a nice day..
Feb 18, 2011 | Sony STR-DE575 Receiver
Hello Protection Samsung HT-DS900
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 14, 2009 | Samsung HT-DS400 System
Spa turns on by itself.
if no spa programs remove spa side remote if it goes away replace remote
Mar 24, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Computers & Internet Logo
490 people viewed this question
David Payne
David Payne
