Philips 29PT7322/79R tv will not start up, after
Phiis 29PT7322/79R tv will not start up, after pressing the start button the set sounds ike it fires up but after a few seconds it makesa click and shuts down, the red |LED on the front start to flash
    President:
  • 563 Answers
There is a part inside the TV that needs to be replaced. If the TV is under warranty, call the manufacturer and they will arrange to have your set repaired at little, or no cost to you.
If the TV is out of warranty, and you have the experience and you know what you're doing, you can fix the unit yourself. Otherwise, if you've never done anything like this type of repair before and you don't know where to start, I suggest speaking with an experienced TV repair-person.
If you take the TV to a repair shop for out of warranty repair, the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Since some brands will pay for your repair even if you're out of warranty, you should contact the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Sep 06, 2009
How to setup phillips universal remote to a panasonic tv
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search
Nov 29, 2016 | Panasonic Televison & Video
My Philips 47PFL7422D/37 sound keeps defaulting to Spanish. I know how to reset it with the remote, but it just defaults back immediately.
Hi the link below has a FREE user manual download in it but the question and answer should help you........CHEERS..
QUESTION
I have lost my personal settings. Why is this?
Your personal settings were probably reset after you had switched off your TV because it is still in the LOCATION SHOP mode. In this mode, all settings are fixed and will automatically apply each time the set is turned on.
ANSWER
To store your personal settings, make sure your set is in LOCATION HOME mode:
1. Press the MENU/BROWSE key on the remote control.
2. Select TV menu and press the button
3. Select Installation and press the button
4. Select Preferences and press the button
5. Select Location and press the button
6. Select Home and press the OK button
7. Press the MENU/BROWSE key to browse through the menu
Philips flat HDTV 47PFL7422D 47 LCD integrated digital with Perfect Pixel...
Apr 04, 2016 | Philips Televison & Video
Okay I've purchased a 40 inch tv today and how do I reset everything?
From the User Manual, page 35 (page 36 in the .pdf file):
Return your settings to default values When you return picture and sound settings to their default values the
channel installation settings are not affected.
1 Press MENU on the remote control and then use [the arrow buttons] to select [Setup] > [Installation] > [Reset AV settings] > [Start now].
2 Press OK to reset the picture and sound settings.
3 Press MENU to exit.
You can download a copy of the manual from 40pfl7705dv_f7_dfu_aen.pdf http://download.p4c.philips.com/files/4/40pfl7705dv_f7/40pfl7705dv_f7_dfu_aen.pdf
You may also want to look at "Update your TV software" on the following page of the manual. Updating is not always necessary, unless the update fixes something that bothers you or provides an improvement you want (if it isn't broken, don't fix it). As of this writing, there are two sets of fixes (copied from the "Firmware Upgrade Readme File" at Software & drivers):
Software history:
Version: Problems solved.
PHL-0DA_710_0 - Momentarily looses audio after channel change.
- Time shifts one hour when changing from "Auto Clock" to
"Manual".
- Enables Philips Wireless Media Connect.
PHL-0DA_713_0 - Clock does not keep accurate time.
You do not have to apply both updates; everything is included in the latest one.
Jul 24, 2014 | Philips 40Pfl7705dv/f7 40-inch Smart...
My philips 32PF5531D/10 TV Wont Work
i have same problem.. please if you had found solution help me help me!!
Mar 14, 2012 | Televison & Video
Want to change sound settings (too much bass). how do i do this?
U still have the tv original remote wright?Yes?Used the tv remote press the Menu button.Pick and go into the tv Sound Setting adjustment have all sound functions setting in there.
Aug 23, 2011 | Philips 27PS55S 27" TV
How do i get my tv back to home mode when it is in retail mode
Hello
[1] Press the green color button on your remote control to enter the Settings assistant menu.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
Feb 22, 2011 | Philips 42PFL5332D 42 in. LCD Television
I have new Philips LCD 47"tv and on the bottom
HI:
You may of turned on the Philips Easylink which is for connecting Easylink-compliant devices that are connected through HDMI connectors can be controlled by a single remote.
You can restore the default picture and sound settings of your TV.
1. Press MENU
2. Select SETUP> Installation>Then Factory settings.
3. Select Reset to start resetting
5. Press OK.
6. Press MENU to exit.
Jan 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
1. Turn on the component to be programmed.
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
Electro Med Services...
