Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Finger Switch To get maximum drill rpms, the finger switch has to be held approximately half way on. If you pull on the switch to the stop, the drill also stops. ie; put pressure on the switch and the drill motor starts slowly, add pressure to the switch and the rpms increase to the normal rpm at half way, continue pressure on the switch to the stop and drill will die down and stop.
I NEED TO BUY A NEW FINGER SWITCH TO MY KAWASAKI CORDLESS DRILL MODEL # 840128
Posted on Jun 26, 2008
  • 25 Answers
Call1-800-423-3598,give them your model number so they can send a replacment trigger assy.
Posted on Apr 23, 2008
Harbor breeze outside ceiling. How do I reverse the direction of the blades?? The remote doesn't seem to have a reverse on it.
There should be a tiny plastic switch, almost invisible, on the side of the fan housing that will reverse the direction.
The switch button is about half the size of your pinkie finger finger-nail.
Aug 05, 2016 | Dryers
My cordless drill is running at half RPM. Is it the brushes or the motor?
cordless drills have a switch that allows for more torque at lower rpms si in effect it is a 2 speed drill coupled with a variable speed switch that alters the rpms
If the drill is running I would be looking at a speed control problem at this point I would be looking at the torque control switch
Jul 01, 2015 | Milwaukee Hand Trucks Milwaukee Electric...
How to replace the brake light swith
The brake light switch is most likely sticking. If you tap it with you finger it will most likely operate again. However, I would recommend replacing it. MOst switches are held in place with a nut on the back side of the switch that must be loosened for removal. Others sre held in place by a bushing that will require gentle pull or a twist and pull to remove
Apr 12, 2015 | 1998 Nissan Pathfinder
I have a whirpool LSR7233DQO model top loader washing machine, a month ago it stopped agitating, now it will not spin at all on the spin cycle. It actually sounds like there is movement in the bade of the...
Sometimes the switch goes out (that little thing you held your finger on to keep it running). That's ~$20 to fix. If the washer runs, fills with water and won't spin once it reaches the spin cycle you probably need a new motor.
Feb 05, 2014 | Washing Machines
How do I replace the power mirror switch; 2004 rav4
Gently pry up the plastic around the window switches. It's usually two clips that hold on the switch panel, but some Toyota's window switch panels are held in with a clip at one end and a "finger" at the other end, careful prying on the finger end as it will break. Use the pry and peek technique. The switch itself will likely be held in with snaps or Phillips head screw's. If its the snaps type, CAREFULLY insert something like a butter knife under the snap on one side and pull that side out a few mm, repeat process on the other side without snapping back in the side you just freed. You should now have the switch in your hand. If you ignored the thin butter knife part and shoved a flathead screwdriver in there instead, the snaps are probably broken and will d drove you crazy every time you push down on the switch to hard and it falls into the door panel..
Sep 06, 2013 | 2004 Toyota RAV4
On turning my 6200 on the gps location is showing i am in york which is 107 miles from were i actually am ?? why is this and can i fix it
Try this resetting procedure:
1) Switch the unit OFF with that switch on the button (the one that needs the pen).
2) Now hold the power button on the top with your finger, and switch that switch on the bottom back to ON while keeping your finger held down on that button.
3) Something roughly called the Aragorn Boot Loader will appear and will count down from 5.
4) Release your finger off the power button on the top before it reaches 0 or you will have to start again.
This should have performed a hard reset, and you should be asked to calibrate the touchscreen.
May 14, 2011 | Evesham GPS
I have a DW958 18v drill and it runs and the bit spins, but if you put your finger on it, it stops. might be a gear problem? How do i fix?
These tools have panetry gearboxs to give maximum torque foe lightweight gearing. A common problem with the older DeWalt drills was the gear selector legs coming adrift. This is (potentially) an easy fix. First of all, the obvious stuff. Remove the battery and press the trigger to release any static/stored power. Undo all the screws and seperate the two halves. Try to keep all the internals in the back half like this... http://lib.store.yahoo.net/lib/mendingshed/DW958mainimage1.gif
Now check the metal legs coming down from the gear selector slide. They should be sitting through the sides of the gearbox, and located into the sides of a ring gear. They used to pop out of this gear which would stop it being pushed fully into position.
Nov 23, 2009 | Dewalt 18 Volt Compact Drill Kit
The electronic brake on my drill stopped working.
could just be the switch. while you have it apart I would check the condition of the motor brushes. The switch is around 40.00. Let me know if you need more help
Sep 29, 2009 | Panasonic 15.6v Ni-mh Cordless Drill -...
Dyson won't keep running
THAT IS THE PROBLEM U NEED TO FIX OR REPLACE THE SWITCH
Aug 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
183 people viewed this question
Top kawasaki Drills Experts
Marvin
Marvin
jasbo
jasbo
john h
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
