Question about Vacuums
Kenmore Intuition wand very hard to pull out of head.
I have a Kenmore Intuition Canister, and everything is working fine on it except the following: when I need to remove the brush head for access to corners the wand is extremely difficult to pull out of the brush head. The same is true when I want to remove the entire wand, to use the small brushes. It's as if the wand were too large for the opening. I thought over time it would become easier, but it hasn't. Do I need to sand down something, or use some vaseline or other product? Any help you can give me is appreciated.
  • 430 Answers
No vaseline. You can use wd40 or silicone spray.Also check to see if the wand is bent out of round where it meets the handle
Posted on Sep 06, 2009
When I replaced the bag, the bag replace light comes on unless I don't use any attachments. what is the problem?
Could be a blockage, push a broom handle through the pipe that will clear it.
Oct 18, 2014 | Kenmore Vacuums
Kenmore vacuum model 116
Anthony, glad to have you back, except that you're missing a bunch of numbers. All Kenmore vac's models start with a 116., (notice the decimal after the 6). Then there's at least four to six more numbers that spell out the actual model. If you can get those for me I might be able to help.
Oct 22, 2013 | Vacuums
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
My kenmore progressive vacuum had the same problem. The electrical terminal at the bottom of the wand was corroded. I used a flat head screw driver to scrape the female portion of the connector as best as I could. I then took off the plastic cover on the vacuum head that had the male portion of the connection. I used sand paper to clean the two connection prongs. I also spread them apart slightly for better connection (more interference) when the connection is made. I reassembled, and our vacuum is working fine now. I hope that helps.
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Power head and wand connection is intermittent.
If there is a rubber bumper on your power head you must slip it off before the two halves will separate.
Aug 21, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Progressive canister turns on and off when you pull hose.
I saw this on another FixYa post -- it tells you how to remove the wand cover safely---
Comment posted on Feb 09, 20082bubbles ok here we go.. fine a small file that will fit the holes at the bottom of the wand and break the file so that the flat end fit into the wand. please make sure the wand is not plug in to anything. now put it into the hole and try to clean it out gently not too hard or you will damage the contacts. after that grab a needle nose pilers and very gently press the contacts. not a lot or it won't fit back into the power-mate. ok now for the top of the wand. if you look at the wand where the button is to extent the wand. on each side you will see a small clip. with a small flat head screw driver push into the clip at the point closer to the wand tube. it will pop out. make sure to check the clip to see how to put it back in. after both clips are out you will notice a that the clips left a gap. the back part of the wand or cover will now slip off. push it toward the gap. then up. after removing the cover. you will see a ribbon strip which is attached to the prongs or fuse .you can remove the fuse and then clean the contacts. please be careful. once this is done you then put it all together and try it out. the fuse is a part that you can buy at sears if you have to. let me know if this helps you out. if it seems like too much just take it to sears and ask them to replace the wand fuse for you instead of replacing the whole wand. hope this helps .
Dec 10, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
181 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
