Question about Mercury P4VM800M7 Motherboard
Sata hard divier
How meny supporte the sata hard divier
    President:
  • 1,447 Answers
2 pices sata hard drive support
Posted on Sep 06, 2009
  • Sazeed Computer
    Sazeed Computer Nov 22, 2009
    may be if you need to support another device pci sata or rad hard drive
Cefc cp
Depending on how old your WD hard drive may be....it's either 12VDC
or 5VDC - voltage can be checked on older drives the use 4 pin plugs
(usually white and referred to as Modulex plugs). Newer WD drives
may use SATA cables to power. Most drives indicate all this info on
their labels (top-face of drive). Good Luck.
Apr 18, 2014 | Western Digital Computers & Internet
Sata hard drive not support
The hardware of your system need more hardware capacity and some slots on the mobo for the sata cable.
Apr 29, 2012 | ASUS P4P800S-X (610839118175) Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Need to know if it supports any SATA hard diskS
Yes, the T5212 motherboard supports SATA hard drives. I checked the picture and it has four (4) internal SATA ports.
If you would like to make sure, you may open the CPU and look for four black ports that has a marking of "SATA0 up to SATA3". The SATA ports starts with the zero, that's why you will see SATA0.
Good luck and have a good evening!
Jan 18, 2010 | E-Machines T5212 PC Desktop
I'm wondering if my ASUS K8V-X motherboard will support a 320 GB SATA hard drive.
Check is there ports available for connect SATA HDD. If yes it will support .
Thanks.
Oct 14, 2009 | ASUS K8V-X Motherboard
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Mercury P4VM800M7 Motherboard Logo
56 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
