Question about Cameras
I have a L830/L730 samsung camera and I am getting a message when I try to take a picture of "Card Locked !". How can I unlock the card please ?
I have left my camera to charge but it will not turn on, please can you give me some support. Thanks
Posted on Jun 02, 2010
L830 Digital camera - says "card locked" Tried to move the tab at the side of the memory card but still locked?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 15, 2011 | Samsung Digimax L830 Digital Camera
How do you unlock disk
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Mar 09, 2011 | Samsung Digimax L730 Digital Camera
My Samsung L380 Camera always says "Card Locked!" when I try to take a picture. I can't tke pictures any more!!! But it's not a problem of the card. I tried different cards and it's always the same...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 23, 2010 | Samsung Digimax L830 Digital Camera
Card locked samsung L730 digital camera
Move the slide switch on the side of the card.
Mar 30, 2010 | Samsung Digimax L730 Digital Camera
Samsung SL620 - - "Card Locked" message
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 16, 2010 | Samsung SL620 Digital Camera
CARD LOCKED appears oo screen, camera wont work?
Does this camera take a memory card, separate from the built-in memory of the camera? If so, remove that memory card and look closely at all sides and edges, to make sure that there is not a read-only protection switch on it.
Many of these memory cards have tiny switches, sliders back and forth, that protect the memory from being erased.
If you slid that switch into the locked position without being aware that it is there, and without knowing that you did, then the error message makes sense.
Remove the memory card and look at it very carefully.
-a.
Dec 10, 2009 | Samsung Digimax L730 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Samsung l730 camera
take out your memory card, check the left side that says lock with the arrow down the very side with small white button to unlock slide the up or push the button up to unlock your card.
hope it works.
Oct 19, 2008 | Samsung Digimax L730 Digital Camera
Memory card locked
Sounds like the 'lock' tab on the memory card has been moved to the 'safety' to prevent you from re-writing your card accidentally
Fix it by:
1 remove memory card from camera
2 look for the very little tab/switch on the front of the card
3 slide it to the unlocked position (opposite of now)
4 put it back into camera...should now allow you to take pictures
if the tab/switch is missing do not dispair...
-use a small piece of clear tape to cover this 'tab/switch' opening
-this is the same concept as cassette/vhs/ 5 1/4" floppies...removing the 'tab' to lock it
Sep 10, 2008 | Samsung Digimax L830 Digital Camera
Card locked
Reformat card - have you tried? Check your manual seek help in Samsung Web site Come back if still int rouble
May 06, 2007 | Samsung Digimax 4010 Digital Camera
Cameras Logo
136 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
