Question about Whirlpool LSN1000LW Top Load Washer
The water will not empty out and let the spin cycle start? What can I try before I can the repair guy?
  • 37 Answers
Have you tried looking to see if pump belt has come off or worn out?
Posted on Sep 06, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
I have a Whrilpool washer model LHW0050PQ 2. It will work perfectly then will not spin. At the end of the cycle the done light just flashes. If I choose to just choose spin cycle you will hear it go...
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
Locate and clean the filter. There is a round unscrewable filter cover on the front of the machine at the bottom right, behind a small door. Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter its self and get your floor wet, so take a look for this before you remove the filter and get soaked.
If this IS the case, you need to call the repair guy out again and when he gets there, kick him all round the house until he gives you a refund foe his last 2 visits!
Jul 11, 2011 | Whirlpool Washing Machines
Water wont empty from machine.not spinning properly.clothes v wet at end of cycle.
Hi pauabreen
On the spin cycles (F or J) does your motor attempt to 'spin' up for about a second then basically fail.
Declan
Nov 01, 2010 | Electrolux EW1000i Front Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Mar 24, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
97 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
