Question about Kenmore 63942 Dryer
Spins fine but no heat
I have followed the tech sheet that came with the dryer with no success...had my washer fixed the other day by a repairman and the next day the dryer tumbles normally but has no heat hmmm. Following the troubleshooting the outlet as the right voltage, 240 and 110. The one test I did called for checking continuity from the L1 connection on the plug with black wire on timer, this did NOT have continuity, so they say to fix or repair main wire harness, that a needle in a haystack. I did check the heater and it had 10 ohms of resistance as did the thermistor (too much for the thermistor?), the high limit thermostat had continuity as did the thermal cutoff switch as well as the thermal fuse. Can the problem be the heater relay with everything I have checked? The guide does not mention it or how to test it...the light inside was burn't out, still trying to determine if there is a connection there...Ran diagnostics per guide and checked out...thoughts?
  • nguyenhn61 Jul 03, 2008
    can you please let me know when are these relays located?
    Thanks
    New Friend:
Mine doesnt work at all. i checked the current and the heat duct sensors and the wires, whats next??
Posted on Jun 29, 2013
I solved the problem. The problem was the heater relay. Once I troubleshot the system and realized the wiring was likely good, the only answer was the heater relay. Since the heater relay and motor relay are identical I swapped them to make sure and now the motor didn't work. Picked up a new relay for $30 and it was fixed...
Posted on Dec 12, 2007
Washing f15
Problem:
Bosch Classixx WVF 240S Front Load Washer/Dyer... Won't spin.
Solution:
Recently I had problems with both washer and dryer and I decided to fix them myself.. I did this successfully..
My washer had leaking pump..
The dryer wouldn't heat..
I did the following..
I went to Google and typed in the Make and Model number. I found some info on the Maytag units so I began a note pad on what I was finding..
I would recommend that you do the same...
I found the following:
https://www.youtube.com/watch?v=wlMoT9rgvAg
The information may prove to help you but sometimes calling the repairman may be the best solution.
I listened to a couple of videos on the Bosch and did not feel that I would rely on the information.
In your case I would go to the dealer and ask him what are the most common causes of a Bosch that won't spin.
Next I would ask if they have a manual to DIY as I would like to repair this myself.
Asking these questions from the parts department is also useful if I didn't get plausible answers.
I also found the following on Fixya:
https://www.youtube.com/watch?v=qqGWjxzY-tw
These machines have a level of complexity. I trained repairman is best. If you are very mechanically inclined you may be able to figure it out, order the parts, get a DIY manual (usually availble online through manufacurer), and have fun learning... That is what I did..I fixed them both and saved a few hundred dollars at the same time learned that I could do it (that is valuable to me)..
I hope this helps you,
cmilton111
Oct 28, 2013 | Bosch Classixx WVF 240S Front Load Washer...
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Dryer spins does not heat up
I CAN GIVE YOU THE ANSWER TO YOUR TROUBLES. THE HEATING ELEMENT IN YOUR DRYER IS GONE. CALL A REPAIRMAN AND SEE HOW MUCH IT WILL COST TO GET YA A NEW HEATING ELEMENT INSTALLED.
RODNEY
May 16, 2009 | Kenmore 64812 Electric Dryer
Fridgidare dryer spins but no heat.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
May 02, 2009 | Dryers
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
ERROR CODE (F24) ON A WHIRLPOOL FRONT LOAD WASHER
According to the tech sheet I have, F24 is a water temp sensor error. If the sensor reading is not within specs during the water heating portion of the wash cycle this code will come up.
To find out for sure what this code is for your washer, or for any other service codes that you might encounter, you can look at the tech sheet that is in the washer. Remove the lower front panel by removing the 3 screws holding it at the bottom. The panel slides down and off. The tech sheet will be in a plastic envelope either in the panel or attached to the side panel of the machine, usually on the right side as you are facing it.
You can remove this panel without affecting any warranty you might have because the pump strainer is located there and is user servicable. Just be sure to keep the tech sheet with the washer so some repairman in the future isn't left scratching his head trying to diagnose a problem without the schematic.
Thanks/Mike
Jan 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code for kenmore elite he2 plus
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. Also when you take the cover off you will see a white drain that is covered. Turn it counter-clockwise and remove it - but be prepared with towels because this is the lint catcher and there will be water in it. Clean it out and use a flash light to look up the hose area - I found a lot of loose change in mine.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 63942 Dryer Logo
210 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
