Question about Philips Home Cinema Amp + Speaker system LX600 System
Philips LX600 when I try to put on the Philips LX600 AV receiver it goes onto standby instantly, no output from any sources are heard. Any solutions????
    Problem Solver:
  • 7 Answers
My decoder is not on when i give power supply
Posted on Apr 11, 2010
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
When iam turning on its suddenly go to standby in seconds i have checked with service center their is no problem in it how to check the speakers circut or any wire short circut how to solove this
Please disconnect the speakers and try to swicth ON,If it switches ON without going to standby then one of your speakers is faulty.
After disconnecting the speakers and the set stil goes to standby it means one onre of the protection circuits in your system has been activated,check your fan if its rotating,the output ics if are not burnt or shorted.Also check your power supply section.thanks.
May 12, 2016 | Marantz SR 6007 AV Network Receiver
How do i connect sonos " control " to denon avr 300. Where are audio output on this denon?
The AVR-E300 doesn't have an audio output. It's a very basic AV receiver built down to a price.
Even if you has a better quality receiver, you still would only be able to port sound from analogue sources (ones connected via red & white RCA/phono) to the Sonos Connect for distribution around the rest of your home. AV receivers don't decode audio from HDMI sources to analogue stereo.
If you want to port sound, hook up a source direct to the Sonos Connect's audio input. Don't try going via the receiver.
Sep 14, 2014 | Denon Audio Players & Recorders
Connect ls3100 to av reciever
Your receiver needs to have a SPDIF Digital output, or An Orange coaxial cable digital outlet, or red and white RCA analog outlets (with cord adapter; RCA to 1/8" stereo on the LS3100. You run wires to the R & L speakers and the Subwoofer is wireless.
You can find all details at:
http://www.onkyousa.com/Products/model.php?m=LS3100&class=EnvisionCinema&source=prodClass
Nov 12, 2013 | Onkyo LS3100 - 2.1-Channel Living Speaker...
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
Philips Digital AV Receiver System LX600/69 user-guide
Please log on and post your query to get help:
www.p4c.philips.com/files/l/???lx600_???69/???lx600_???69_pss_???aen.pdf
www.icxinyi.com/zlk/617.htm
Sep 28, 2010 | Philips Audio Players & Recorders
I have lost he remote for my Philips LX600 sound surround system . I need a code to . Can I use one for all remote to replace lost remote ?
For basic and advanced functions,I've had REALLY good luck with Philips Universal MULTI-FUNCTION remotes- Particularly the long slender silver multi-function models,and they will come with Philips functions pre-enabled-just be sure to get one w/the CORRESPONDING button for amp/receiver/stereo/stereo in-a-box,and check back of remote package to see if it operates Home Theater In a Box [HTIB] However,w/OneForAll remote,you would need to give the model # of the remote. Good Luck!
Dec 21, 2009 | Philips Home Cinema Amp + Speaker system...
How to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
Oct 20, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Philips Home Cinema Amp + Speaker system LX600 System Logo
230 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
