Question about Whirlpool Freezers
My whirlpool american fridge freezers water dispenser is continually dripping what can I do to resolve this problem
When i press the water , nothing comes out. the ice works fine but nothing from the water. What could the problem be?
Posted on Dec 27, 2009
  • Whirlpool Master
  • 1,606 Answers
Replace the water inlet valve , the piece that the wall water line connects to on the refrig .. Something like a grain of sand , piece of dirt etc , is caught in the rubber bellows , not letting the valve close completely . This will cause a scratch , which will collect anything else that comes thru , so cleaning it out will not work . ( it won't remove the scratch ) .
Posted on Sep 06, 2009
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Mar 20, 2009 | Freezers
Whirlpool american fridge freezer
Hi, this problem IS caused by components that have failed in the rear module! Fact!
There are a few people that sell the kits to repair them on a big auction site.
Hope this helps
bb
Aug 30, 2008 | Freezers
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
Freezers Logo
197 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
