Question about Garden
How to replace an alternator on a silplicity
How do you replace an alternator on a silplicity regent tractor? My battery is not charging and can't even find the alternator part #.
    President:
  • 986 Answers
It built into the flywheel,you could have a external reg that could be at fault, that should be built in your flywheel cover
Posted on Sep 06, 2009
L1650 does it have a charging system??
All riding mowers that have a battery start have a charging system, per se, that runs the tractor after starting and provides charging power back to the battery. If this wasn't the case batteries would need replacement about once a month, unless you placed them on chargers between use. That said, the don't use the type of alternators that cars do (at least not the smaller tractors), they use stator-based alternators. Here is a sample of what one looks like schematically (from a Kohler-engined Cub Cadet) (yours may differ slightly).
Oct 21, 2015 | Garden
Battery Light comes on, sometimes goes off.
have battery and alternator tested your battery may not be holding a charge or alternator damaged by jumping tractor
Aug 13, 2015 | 2005 Chrysler Town & Country
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
Replaced battery and will not make a sound. old battery started to smoke and tractor just quit. what could have happened
Charging control system has failed and is overcharging the battery. Probably the alternator diode, not sure if it's a replacement part on this model, you may need to replace the complete unit.
Nov 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor
charging system need to be check... alt. some of these tractors have the charging reg. inside alt some have one mounted outside follow wire the red one should be one big (thick) one and a thinner (smaller one) this small one is the charging circuit. if it goes from battery to alt. then regular is inside alt.
Oct 04, 2017 | Craftsman Garden
John Deere 4100 compact tractor will not keep a charge. Has a magnet alternator,new battery ,and new voltage regulator. If you external charge battery, will start & run till useup charge. Then tractor...
If you hold a wrench against the back of most alternators when it's running the wrench should be attracted to the alternator which would indicate that its charging. If it isnt' charging then the regulator inside the alternator is burnt (typically) if it is charging then check the wires to & from the alternator.
Nov 24, 2017 | Cell Phones
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Simplicity Regent Starting Problem
The wrong seat switch was installed. There are black ones and gray ones. I believe you need the gray one for open circuits.
Aug 10, 2012 | Simplicity Regent 19.5/38
Have a Yamaha YT3600 lawn tractor. The battery is good but mower will no recharge the battery. replaced battery and have the same problem. my knowledge of the electrical system on this lawn tractor is...
the starter puts out the amps to charge the battery, you have do an amperage check to find out what its puting
any good parts store will set you up with an inexpensive tester
Jul 23, 2011 | Garden
Battery doesn"t charge
I don't see how this is related to the float?
With the engine running, measure output voltage from the alternator/charger at the battery. It should be about 13.5 vDC. It should increase a little bit with higher revs. If voltage doesn't change with engine running vs. engine off then you probably have a bad alternator which probablly has to be replaced or repaired by a service shop.
Jul 18, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
