Question about GE WBSR3140DW Top Load Washer
Washer not spinning the clothes completely
The washer spins the clothes however the clothes still come out heavy and wetter than usual. the belt has been changed and this did not help. The washing machine does not have water inside so it appears the water is coming out.
  • 7 more comments
  • Disckrazy Dec 13, 2007
    Spin cycle does not get the water out of the clothes. They are to wet fot the dryer.
  • Anonymous Dec 20, 2007
    I have a GE model WWA8955. It has a two speed spin cycle. It doesn't appear that the fast speed is working. The clothes finish wetter that usual
  • Anonymous Dec 26, 2007
    Intermentantly will run thru cycle fill and agitate correctly not always advancing thru spin cycle. When spin cycle doesnt commence it seems to just run pump and not spin. I can hear the timer timing and am unable to get timer to shut off with knob. Will power down for while and then am able to shut off timer. Then other times it works fine
  • Zookie09 Jan 20, 2008
    My washer is not spinning and clothes are soaked
  • sparkey23 Jan 30, 2008
    first i was told it might be the timer but I changed that and the cloths still very wet. was also told it might be valve at the back letting some of the water back in and another problem maybe the pump was not getting all the water out HELP
  • danduitsman May 08, 2008
    same problems as everyone else. goes through cycle but still soaked when complete.
  • powelldt Dec 16, 2008
    The washer sometimes spins and sometimes does not spin. The water drains but the clothes still come out very wet.
  • Anonymous Mar 21, 2014
    Machine begins to spin but then it starts hitting the inside of the machine
  • Anonymous Mar 24, 2014
    Washing machine appears to be spinning as normal but when cycle finishes the clothes are wetter than normal
    Problem Solver:
  • 7 Answers
For the the initial filling of the tub, the pump is not involved. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added. Try removing front (or top) cover and find the water pump. It will have connecting hoses clamped to it. Check the hoses for blockages first. Then check the pump for any objects inside or broken impeller blades. If impeller is broken, replace it only if possible --- if not, you'll need to purchase a new pump. Hope this helped.
Posted on Dec 22, 2007
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Clothes are still wet after full spin cycle
Possible that the SPIN Speed is too low, check the drive, the RPM of the motor. Check for friction of the spindle , check for free movement of the drum. If you notice a change then you will need to reset the mechanism. If the motor speed is low check the capacitor.
Jan 24, 2013 | Hotpoint WMA64 Front Load Washer
Dryer not working. Clothes wetter than when they went in?
Could be that the RPM is not enough for the spin as the BELT is loose or slipping or if the motor speed is less due to a worn out CAPACITOR.
Try with a longer drying time or manually dry to confirm .
Also check if the inlet valve is working at any time during this cycle to we the clothes, if so there could be output from the control panel which could be a suspect.
Jul 05, 2012 | Fagor 24" Washer/Dryer Combo with LCD...
My washer is still spinning the cloths but the clothes are much wetter that they used to be after the spin cycle. Any ideas of how to trouble shoot?
Check your belts and also check the drain hose to be sure it is pumping the water out at a good pace. Hope this helped.
Jun 08, 2011 | Maytag Ensignia MAV4758AWW Top Load Washer
Why does my Whirlpool washer LXR 7133JQ1 washer not spin the water out of my clothes like it should?
Is the high spin function set? Are you putting too heavy of a load in.. ? The more clothes you put in, the wetter they'll be when done.
Mar 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle not working like it should
If the washer doesn't reach it's proper spin speed, the clothes may be wet at the end of the cycle. Since you have replaced the belt, it could be that you have a worn motor pulley or tub bearing. Check for damage to the pulley and shaft and for free play. Also make sure that there are no clothes or foreign objects caught between the inner and outer tubs or something causing friction on the drive train. Hope this helped.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore model # 110.22632.100 does not spin real fast inspin cycl
turn dryer on & make sure that the drum on your dryer is spinning, this could be a belt issue going bad or if the drum is not spinning the belt has broke. It also could be the lint system needs to pulled appart and cleaned out with a chop vac. It could also be exhaust tube kinked behind the machine.
Jul 02, 2009 | Kenmore 23012 Top Load Washer
Occasionally won't spin and when it does it is not at full force
You need the coupling replace between the motor and the transmission.  It's a $20 part.
Mar 12, 2009 | Kenmore 46462 Front Load Washer
Fixing lg whasher
??? not enough information, what do you mean by this? the clothes are still wet when they come out the machine does not spin at all?
the machines have a set time to drain before they spin usually three minutes if the water has not dropped below a level before the set time the machine will stop, check the drain
Clothes begin to get wetter than before? how old is the machine motor brushes usually last 2-3 years depending on usage when they wear down the parts of the program that put the most power through the brushes can fail first (Spin)
Nov 21, 2008 | LG WM-2277HW Front Load Washer
GE WBSR3140DW Top Load Washer Logo
960 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
