Question about HP OfficeJet J4580 All-In-One Laser Printer
Tricolor error--trouble shoot-cartridge error. I can I fix this?
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
It is reading Print cartridge problem(tri-color)
if it is not yet empty try to remove and reconnect the cartridge, if same error, try printing without the tricolor cartridge. if that works, you need a new tricolor
Mar 14, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer Lexmark X4270 is displaying on it's screen always Error #1203. what can I do?
error 1203 is cartridge error, cartridges has a short
1. press power button to turn off your printer
2. unplug your printer to the wall outlet
3. plug in your all in one
4. reinstall your cartridges
if this does not resolve the problem replace your cartridges with new one
for more trouble shooting option :
1. click start> program> lexmark 4200 series> lexmark solution center
2. click the trouble shooting tab on the left side of the screen
i hope this helpful
thank you for using fixya
Feb 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a HP C4780 printer - does the 300XL cartridge work on this model
The HP Photosmart C4780 All-in-One does not use HP 300XL Cartridge.
Below are the cartridges used by your printer with the no. of page count and their price as per HP
HP 60 Black 200 pages $14.99 HP 60 Black/Tricolor 200 black, 165 color $31.99 HP 60 Tricolor 165 pages $19.99 HP 60XL Black 600 pages $34.99 HP 60XL Tricolor 440 pages $40.99
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 04, 2011 | Office Equipment & Supplies
TriColor only prints pink
make sure your both the cartridges are working properly and it is not dry just remove the color cartridge and clean it with tissue paper and fix it again . If still there is problem change the color cartridge.
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 25, 2010 | HP DeskJet 812c InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
I've tried trouble shooting "print cartridge error" plus print still in queue message. I've cleared both but messages still returns with copy, fax and scan lights blinking.I've tried the posted fixes but...
I had this exact error not to long ago. There was nothing in the book to help. I just finally changed my black ink cartridge. That stopped the error message.
So if you haven't tried that, put in new cartridges. Hope this helps.... :0)
Apr 26, 2009 | HP Officejet 5510 All-In-One Thermal...
Hp 6310 Cartridge error
I contacted HP customer service and was given a solution that worked for this precise problem: "Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clearn, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom."
This worked for me. At least immediately. I hope it doesn't happen again.
Jul 17, 2008 | HP Officejet 6310 All-In-One InkJet...
HP OfficeJet J4580 All-In-One Laser Printer Logo
120 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
