Question about Canon Pixma iP4500 InkJet Printer
Unable to feed paper - Canon Pixma iP4500 InkJet Printer
    Brigadier General:
  • Canon Master
  • 3,614 Answers
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Posted on Sep 06, 2009
MAKE SHOER THAT THERE IS NO SMOL BITS OF PAPER ARE STUCK IN THE FEEDER
Apr 01, 2016 | Canon PIXMA MG3150 Inkjet Multifunction...
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Unable to print - mangles paper
Hi
Try turning the printer off and on.
Check through the paper paths and remove any stuck papers.
Avoid filling the paper feed tray to capacity.
Make sure the paper you're using is the correct type and size for your printer.
Align the paper correctly on the feed tray.
Feb 27, 2012 | Office Equipment & Supplies
P26-dh III - I am also unable to load the printer paper. I can't figure out how it is to be fed in.
It is necessary to feed the paper through a slot on the back of the printer in the dark gray area. Feed a single paper through and push the FEED button. When you see it appear, feed the paper through the clear serrated slot on the top cover over the printer.
Mar 18, 2010 | Canon P1-DHV Calculator
No paper jam, but keeps stating printer error-check paper.
This is an indication of the machine being unable to feed the paper. Since this is a rear feed machine sometimes things can fall into the paper feed slot so I would remove the paper and look into the port where the paper goes. Also while your there look for a small rubber tire that feeds the paper in. If you can get to it try cleaning it with a cloth and some glass cleaner. They will get paper dust built up on them and not feed properly.
Good Luck
Oct 20, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
My screen says unable to init. check manuel
Try cleaning the rollers located around the paper feed and making sure there is no obtructions in the way of the paper.
May 07, 2009 | Brother MFC-5840CN All-In-One InkJet...
My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Dec 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Unable to scan with paper feed
Plz name your mfc, your operating system and the country your are from. post it here.
Nov 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Canon Pixma iP4500 InkJet Printer Logo
310 people viewed this question
old marine
old marine
