Question about Music
A couple of the keys on our electric Yamaha Clavinova fail to bounce back after being depressed.
  • 62 Answers
Unfortunately this is not a problem that you can fix yourself. It could be a small spring, a nylon balloon or a micro switch or one of thousands of things they use in the making of keyboards. I would take it to a reputable music shop that knows the product and can expertly repair it. There may even be one who does house calls.
Good Luck
Posted on Sep 13, 2009
All of Clavinova natural c keys are not working.
fauly cable,rust might have eaten up the terminals if you stay in a n area with high humidity..moist settles...or a small intreface card called mks is faulty.
Sep 09, 2014 | Yamaha Clavinova 35 Diskette Christmas...
How do i replace one key on Yamaha YDP161?
A YDP uses the same key type as a basic Yamaha Clavinova. As you have stripped the keyboard to reveal the keys take a look at the end where the key hinges. There will be an arrow pointing to one side. You will need to remove att the screws holding the key base (black plastic ) to the wooden base. Slide the whole keyboard back a couple of inches, push down where the arrow points between the keys, the offending key will pop up. Slide forward and jiggle out. Replace key. reassemble. If the tag on the back of the old key has snapped off remove the piece of debris that might be there before refitting.
dan@beckettsmusic.co.uk
replacement keys can be found online
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17431
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
Yamaha clavinova repair
I Bim
which clavinova model you have
Jan 19, 2014 | Music
Clavinova: no sound from one key only. Rest perform ok.
Likely the key contacts are dirty. These are likely conductive rubber type and have to be cleaned with 99% isoprophyl alcohol.
With the amount of disassembly required to get at the contacts, you best clean them all while you have it apart.
Use 99% (not 70% rubbing alcohol) and Q tips to clean both the circuit board and the rubber "pill" contacts.
May 13, 2010 | Yamaha Music
Yamaha clavinova CLP200 the amp has lost power
I might suspect that the volume control itself may have a break in the resistance element by your description. There can be many causes however including LOOSE CABLES. IF the unit has been moved recently, then a loose cable MIGHT be the cause. In any case, servicing iis required. If you are not familiar with electronic repair you will need to find an experienced repairman.
Nov 08, 2009 | Yamaha Music
Yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Oct 12, 2009 | Yamaha Music
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Music Logo
161 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
