Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
SD2500D032-000 isn't running but the light is on ...
I got the following model: SD2500D032-000. Since a few days, the light on the front is on, but the disk isn't running. Therefor the disk isn't recognized by the computer. What can I do?
  • 32,281 Answers
Sound like the hard disk is faulty or the drive adapter case electronics is faulty.
Remove the hard drive from the case and test the hard drive in another case or in a computer as a slave drive.
You can them work out which is faulty, and then replace the faulty component.
Posted on Sep 06, 2009
2004 Chevy Cavalier engine light and trac off light
One year ago---your check engine light came on
The PO405 code was for an EGR Valve issue
No mention--- if you had that fixed
A Few Days Ago---you get Trac Light on,that is part of
the ABS Braking System
Now that system has to be diagnosed & repaired,not just
continue to use the car,actually make the repair, before
you do some damage or can't stop the car & worse things happen
Changing Trans Fluid---is NOT a FIX for anything,but should
be done on all vehicles every 3 years.
If the Engine Management System isn't working correctly,then
your trans won't work as it should either
You need to be proactive & immediately have any abnormal
operation or check light problems, at least diagnosed in a few days
of noticing them
You need to stop using any car that isn't 100% & have it
repaired as soon as possible.
Not wait weeks or years.
Being 9 years old, the trans may also have it's own issues
Jun 09, 2012 | 2004 Chevrolet Cavalier
2007 subaru forester: why is check engine light on?
The CEL and Cruise blinking is the error indication. Could be any of several issues.
1. The gas cap is loose, or leaking. This is a VERY common error and is written up in the owners manual. The fuel filler neck could have a leak or rust hole.
2. A small exhaust leak on the "donut" gasket in front of the catalytic converter can cause a"cat inefficiency error", fixable by replacing the donut. For an '07, it unlike that the $200+ fuel/air O2 sensor or the cat needs replacing.
May 05, 2017 | Subaru Forester Cars & Trucks
What does E40 mean?
Here's the repair manual for your model: manuals...asher_2004.pdf
There is a test chart in the troubleshooting section you can follow. Test#7 on page 62 talks about the door latch/lock, it asks if your door strike is broken, I've seen a few break before myself.
If you replaced the door latch assembly and its still doing it, and the door strike isn't broken then it said your control board is the culprit.
Hope helps.
Sep 19, 2011 | Frigidaire GLTF2940ES Front Load Washer
GE side by side freezer/refridgerator stops working. I turn it off, wait a bit, and turn it back on. Then, it works for a few days before I have to turn it off again. Sometimes I have to unplug it. Now, it...
One thing to defienently check is the condenser coil for extreme dust build up by removing the front grill below the refrig door and clean ALL dust from it. Also if it isn't too dusty pull the refrrigerator out and remove lower service panel from back and check if the fan motor by the compressor is running.
Use a refrigerator coil brush like the one in this image http://www.acehardware.com/product/index.jsp?productId=1279693&CAWELAID=109384350
it can be purchased from your local hardware store,ace,home depot,lowe's or appliance parts store
Gene
Aug 11, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
GE Refrigerator isn't cooling properly freezer is freezing ice
You have a defrost problem !
The fridge isn`t defrosting automatically . Although it`s likely the defrost timer motor seized , it could also be the defrost termination switch , also known as the DTS switch , (or limiter switch) ..... or the defrost heater itself .
Any one of those three will give you the exact same symptoms .
You can diagnose this problem yourself simply by emptying the fridge , unplugging it with the doors slightly open , and letting it defrost for a good 24 to 48 hours .
Plug it back in , and let it run for about 12 to 18 hours . If the temperatures are OK after that , and remain OK for a few days , the problem is exactly as I described .
A defrost timer is worth about $30 to $40 .......... a DTS about $10 to $12 ............. and a heater anywhere between $25 to $75 , depending on the model .
Jul 03, 2011 | GE Refrigerators
Continuous green flashing light
ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Jul 31, 2009 | Televison & Video
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
Engine skipping/misfiring, engine light flashing
Drive it into a dark place, or wait till dark. When it's running poorly, see if you can see any spark flying around. It sounds like plug wires.
Mar 04, 2009 | 1995 Mazda Millenia
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
