Question about Toshiba HD-XA1 DVD Player
Toshiba SD V290 dvd video & Cassette recorder combo
My unit when I put a dvd in to watch, the door will open about 3 times before it will stay closed and play the movie.
  • 158 Answers
SOURCE: DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Posted on Aug 13, 2007
  • 4234 Answers
SOURCE: Toshiba model sd-v383sc
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
Dan
Posted on Jun 19, 2008
arthurroger
  • 170 Answers
SOURCE: I have a toshiba DVD
Use your remote to access the set-up menu. It will ask you what language you prefer for on-line menus. It might read "idioma". Scroll through the menu options until you find on-screen language,. then select English.
Posted on Dec 03, 2008
  • 35 Answers
SOURCE: Trying to program comcast remote to work with my
http://www.comcast.com/corporate/customers/customer_support/remotes.html go there and click the remote your using and then find the brand and get the code
Posted on Jul 12, 2009
alexander404
  • 276 Answers
SOURCE: Looking for the operating manual
Try this:
http://www.tacp.toshiba.com/tacpassets-images/models/d-vr610/docs/d-vr610_om_e.pdf
Download
Posted on Aug 18, 2010
I am looking for code for URC-4220 for my Toshiba DVD/Video Cassette Recorder SD-V290
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily..
http://electro-medical.blogspot.com/
Jan 11, 2017 | Toshiba Televison & Video
Why does atr appear on vcr sreen
Borrowed from Toshiba's site: Unfortunately this unit was meant to record from DVD to VCR and not VCR to DVD. The DVD section of this unit is a Player only and does not record. I was not able to find an "atr" function on the unit. If you meant OTR that stand for "One Touch Recording."
Jun 12, 2014 | Toshiba SD-V290 DVD Player/VCR
The DVD disc tray door will not open either with the remote control or from the front panel. Thank you.
if the open sign comes on the dvd player it is still working the is good news you will just need a new cog with new teeth on it
Dec 20, 2010 | Toshiba SD-V290 DVD Player/VCR
I have a DVD in my SD 3990SU - it won't play and the door won't open using the remote or the button on the front of the unit. is there an alternate way to manually open the cd loader.
You will need to open the set and manually move the motor drive to manually shift the drive to release the Cd.
Now check the voltage to the drive and also check the power, the main board drive circuit, the motor .Check the control signals to the motor drive , if absent the processsor control is faulty.If present the drive IC is faulty
Sep 26, 2010 | Toshiba SD-V290 DVD Player/VCR
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
Dvd/vcr player
sometimes this is openend by a small rubber belt or a worm mechanism driven by a rubber belt,take off top and see if belt is slipping,
Jul 19, 2009 | Toshiba SD-V290 DVD Player/VCR
Dan
Jun 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba HD-XA1 DVD Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
