Jenn-Air 24 in. JDB1100AW Built-in Dishwasher
Problem for Jenn-Air 24 in. JDB1100AW Built-in Dishwasher
Jenn Aire dishwasher DW861upq leaks
By shanaghanp on Sep 06, 2009
it leaks underneath near the plastic wheel. Any thoughts on which part I need to replace
Thanks,
Pat
Solution #1
posted on Sep 06, 2009
Not Rated)
rylee_smith
Rank: Guru  Dishwashers  Expert
Rating: 88%, 1032 votes
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air 24 in. JDB1100AW
Questions and Unsolved Problems for Jenn-Air 24 in. JDB1100AW
Do you recommend Jenn-Air 24 in. JDB1100AW Built-in Dishwasher?
Answer
Answer
Control panel buttens are quirkey. Some buttons no longer activate.
Answer
The all-in-one dishwasher pellet pops out of my new Jenn-Air dishwasher. I know that the soap holder... (More)
Answer
Jenn-Air JDB1100AWS Dishwasher approx 3 yrs old. The dishwasher is stuck on normal wash with heated... (More)
Answer
I have a Jenn-air jb1100awb-- the closure doesn't work any more-- i have taken it apart and opened... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , IL
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
