Question about Panasonic PT-47WX49 47" Rear Projection Television
PICTURE GOES WAVY AND DISTORTED AFTER APPR. 15 MINUTES AFTER TURNING ON, YOU CAN TURN IT OFF FOR 10 MINUTES NAND IT WILL PLAY FOR ABOUT 10-15 MINUTES UNTIL IT GETS WAVY AND DISTORTED AGAIN
  • SOLEMAN Dec 10, 2007
    picture goes wavy after 10-15 minutes
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 10, 2008
Tv is waivey when you first turn it on
What is the TV brand and model number? In general when its wavy or 3D looking its a convergence failure....but if it corrects itself occasionally then there may be second problem that will have to be resolved first.
May 18, 2013 | Televison & Video
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
When you turn on the the TV the picture is good with in a minute or so the Picture turns wavy and has a double image. I can turn it off, then turn it right back on the picture is good for any where a...
The problem with the television is the lamp. It is faulty that is why the screen turns wavy in minutes.
The solution to that is to replace the light and your television will be in good condition once again.
Take care
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my 50H82 it takes 10 to 15 minutes
I just did a repair on one of these. Check your picture-on-picture. If the the secondary picture is clear, chances are very good the problem is on the "hyper board". We d not replace the hyper board - we repair it. The board is very expensive and rarely, if ever, available. There are several parts in the module that need replaced, but these are definitely not user replaceable. They are very small surface mount components and even I have lifted a copper or trace or two doing these. It is tedious work but our repair bill was well below $300. It is also something I do not do in the home and taking it to the repair facility is a money saver. I did go to the home on this one and remove the board to the shop, however they only lived a few miles away so the service call was low priced. Hope this helps...
Feb 23, 2009 | Toshiba 50H82 50" Rear Projection...
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Panasonic PT-47WX49 47" Rear Projection Television Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
