Sony TV : RM-Y1101 When I switch on, the picture & sound appear for a second or two, then the set goes into standby mode and I can't seem to get it to come back on.....can you please advise me ?
  • SD Tech
    SD Tech May 11, 2010
    the rm number you gave is the number on the remote control---what is model number on back of TV? KV-...........? Also, most of these sets the power light will blink a specific number of blinks if the set shuts off....... REGARDS, SD TECH
5 Suggested Answers
SOURCE: Sony tv keeps going into standby mode
the tv is probably placed n a tight spot and getting over heated or even if its n a good air circulated area u may be leaving it on to much and its overheating anyway or its your lamp it may b out i heard they only have 1000 hours of operation the lamp operation not the tv itself ----K.O.
Posted on Jan 02, 2009
  • 116 Answers
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Posted on Oct 01, 2009
SOURCE: the picture comes for 2
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Posted on Feb 26, 2011
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Standby mode
I have the same television. Mine would shut off and turn back on every 30 seconds. Even though the LAMP light wasnt coming on in the front of the set, I replaced the lamp with a factory Sony lamp and have had no problems since. The sets picture is beautiful and I have had no problem since.
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KP-53HS10
The problem seems to be in Secondary supply of Switching Power supply.
Mar 31, 2008 | Sony KP-53HS10 TV
Sony KV-28CL10U TV
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 08, 2017 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Set powers off seconds after power on
* Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. That would be the fly back transformer and the horizontal output transistor.
Jul 14, 2007 | Sony KP-51WS510 51" Rear Projection...
No Picture, Sound Fine
Hey John, How many times does the light blink? No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. I suggest you do a hard reset. Unplug the power cord for 4 hours. Then plug it back in and check it. If it works, great. It not, cost of repair for this is usually around $150 - $250 plus the house call.
Jun 26, 2007 | Sony KV-27S36 27" TV
Televison & Video Logo
692 people viewed this question
Top Televison & Video Experts
