Question about Gateway Computers & Internet
What do I need to install/add to WinXP Pro to allow Maxterm thin client terminals to work?
  • 1 more comment
  • johnleathers Sep 06, 2009
    Your answer was a waste of time, I don't need instructions on installing XP. Please read my question.
    "What do I need to install/add to WinXP Pro to allow Maxterm thin client terminals to work"
    the first person to attempt to answer my question sent me a link to "how to install XP". Obviously didn't even take the time to read my question. Hopefully someone else will.
    "support software of the Maxterm"??? define support software. Obviously I need some software, otherwise I wouldn't be having a problem. What support software?
    Brigadier General:
  • 5,158 Answers
This is your minimum system requirements for that to work
Memory: 128 MB SDRAM, Up to 512 MB
- Flash Memory: 128 MB or 256 MB
- Graphics: 64 bit 2D/3D graphic engine and video accelerator
- Video: 1280x1024 16 bit color or 1024x768 32 bit color
- 3D sound system complies with PC98 audio specifications/Audio-out and Mic-in.
- Built-in 10/100 Base-T Ethernet interface
are you getting any error messages ?
Posted on Sep 06, 2009
    Brigadier General:
  • 3,614 Answers
You will need a support software of the Maxterm and install it on yuor computer
  • 601 Answers
Check this link this will help you
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
Thanks
Smith.
Thin client
It is a network terminal, you don't have to install anything on it...
... but you need an application server to run on your LAN to use it !
Oct 13, 2013 | Microsoft VXL Itona TC4421-XP Thin Client...
Hi. I want to set up a server and run dumb terminals (thin clients) off of it. Can anyone give me a basic run-down about how I do that?
You would setup Windows Server. Windows Server 2003 and 2008 Small Business Server comes with a license of Terminal Services Server.
You would first need to setup your Windows Server. Install it according to at least minimum requirements.
Make sure you assign this server the correct role. If this is the primary server and if you intend on hosting dns and dhcp on this machine, then please make sure you are assigning this server these roles.
You will need to create user accounts so that you can log into from your thin clients.
Next you need to run the install for Terminal Server.
Next you need to configure each thin client.
Next try to access each thin client via Remote Desktop as well as the server.
This is the basic run down of the process. If you do not know how to setup a server then you will need to ask that question as this is very detailed. Also you will need to be more detailed in your question as to whether this is a linux based network or a windows based network.
Hope this helps. Please don't forget to give me a good rating as well as your vote.
Apr 02, 2010 | Network Computing Devices (NSH800S/A)...
I am unable to on my thin client it is based on windows server
check your server RDP policy in terminal server configuration,double click RDP permission tab,add user everyone,set full permission.
Nov 13, 2009 | HP Compaq Thin Client T5300 (dc643a#aba)...
Compaq Evo T20 - Performance sluggish
its 16 years old now.
is this the only slow client.
after all a terminal server always serves many, not one.
if only 1 client is slow that it needs work.
what can that be,?
well , check that all software in the client are fresh and clean.
reload it?
like NIC card, driver , try another port on the router to the slow
client.
to the full reset yet and reload all software and re configure
it per the manual>?free it is, and very OLD.
https://www.manualslib.com/download/359290/Compaq-Evo-T20.html
id say the client has issues if the mouse is slow, all the time.
Dec 25, 2017 | HP Compaq Evo t20 Network Terminal
Neoware ca5
True, even if you reflash the system to bring it to a fresh state, it will still need a server to do anything reasonable.
Head over to http://www.neowareftp.com/ and click on the "Tech Support" link. A password dialog box will show up: [since it may violate TOS here I won't post that info, but it's readily available on the web.] Once in, click on the FlashRecovery link, then pick the flash that relates to your machine - CA5's are usually the CE versions. Download the file.
Now, this program will work on XP systems. Install the program and follow the directions. You'll need either a cheap hub, switch, or a simple crossover ethernet cable. Hook the thin client to one end, your PC to the other, run the tftpd32 program as described in the documentation, set up the thin client per documentation.
If all is done right, your thin client will grab an ip address from the tftpd32 program and you'll see the reflash menu. Pick the number corresponding to the proper reflash, and watch the machines do the rest.
When it's done, you'll have a pristine OS on your device.
now understand, these are made primarily for accessing terminal servers in businesses or schools or hospitals, so it may be useless unless you just want to do some primative web surfing (the CE version has an embedded version of IE5, no java, no flash, and probably no room to put it on that 16meg flash disk.)
But if you buy these devices for a accessing terminal servers, this will give you a clean client.
Jan 21, 2008 | Neoware Systems c50 Thin Client Network...
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
Computers & Internet Logo
20 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
