Question about Sewing Machines
Thread is knotting up on the underside of the fabric - what do I adjust. I am using a Singer 438
  • 632 Answers
Try pulling your top and bottom thread to the left side of the foot before you place the presser down and start sewing.
Posted on Sep 06, 2009
My singer 6136 bobbin keeps knotting up
Are you getting knots under the fabric when you sew? If so, that is bird nesting (thread nesting) and is commonly a top thread issue. Most often the thread is not seated fully in the tension disk or the top tension setting is off.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the tension at the midway point and then tweak it so the top and bobbin threads meet in the middle of the fabric.
Jul 20, 2017 | Singer Sewing Machines
My stitch does not sew on right side of fabric. I sew & see the underside of the stitch. I remove the fabric & the stitch is on the underside.... Never known sewing machine to do this. Help!!
Hi. first thing is to remove the threads from the machine, top thread and the bobbin, and replace to manufactures instructions. If still the same the problem sounds as if there is no tension on the bobbin [under] thread, adjust to a light tension. Then adjust top thread tension until the knot is in the middle of the cloth. Most times people keep tightening the top tension..
Aug 10, 2013 | Brother XL-2600I
Thread mess at the underside of the fabric
On the bobbin holder there is a smaal screw, thghten the screw to set tention on the bobbin thred. The thred you use on top and in the bobbin can be the problem as well E-Mail me wcbotha@yahoo.com
May 10, 2010 | Singer 8280 Mechanical Sewing Machine
Hi, maybe your bobbin is turning the wrong way and you need to flip it over. Or you don't have any top tension. Be sure the thread is in between the tension disks with the foot up. Its also possible that there is a burr on the hook part that goes around and grabs the top thread. The thread will catch on the burr and cause this issue. Usually after breaking a needle. Then the burr would need to be polished off.
Mar 18, 2010 | Singer 8280 Mechanical Sewing Machine
Bobbin continues to pose problem - knotting thread underside of fabric,
In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
USE GOOD THREAD!
Thanks,
Bonnie
Oct 25, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 5525 sewing machine knots up thread on underside of fabric after three stitches
most commonly this is from incorrect threading top thread. Check manual for threading path or follow threading path usually marked by arrows on machine
Sep 10, 2008 | Singer 8280 Mechanical Sewing Machine
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Sewing Machines Logo
126 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
