Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WT960 Flashing F-05
Looked up this error code - Pressure switch jammed on fulled, can you explain how to fix this problem. Thanks
  • 1,031 Answers
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Posted on Sep 06, 2009
Thanks for this it encouraged me to have a go. Couldn't get the pump p
P
Out but in the middle of that whole is a large black rubber pipe attached on by a steel ring with a little screw to open and tighten this. I unscrewed it and pulled off ( word to the wise drain any water first by dropping the grey drainage hose to the floor into a bucket first). Inside this is a basket with a ball in it, lift out the ball and see what you can find! I found a wire from my bra and three coins - stopping the ball from rolling and the drainage from working. Put it back on in reverse order, screwing the ring on the rubber pipe nice and tight. Hurrah. P.s. Yes I am a woman.
Posted on Jun 11, 2011
    New Friend:
Thanks all! Determined not to be beaten I did the same. As long as you do not mind the thick slime make sure you clean out that black rubber pipe where the ball is, very well. Just doing a test run on mine now, hopefully no puddles anywhere. If it works I've saved pounds and if it has not then I haven't lost anything except a bit of time. Have a torch and cloth ready, once you take that back board off and you're lying on the ground in an awkward pose, the metal cuts into your wrist a bit as you're unscrewing the pipe. Place thick cloth over the metal, much comfier. Good luck all - go on ladies have a go!
Posted on Jan 04, 2013
Hotpoint wt960 keeps displaying f05
Seems that the pressure switch is jammed and so it does not cut off supply or is cutting off inlet water to the washer. Remove the lines to the pressure switch and reset, check the pressure switch diaphragm
Click pressure switch
Error codes for Hotpoint
Jan 20, 2013 | Washing Machines
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
Its showing F 05 and all lights are flashing its a hotpoint model wmf740k
The error that you get means that the pressure switch is jammed on full capacity. Please try using with less loads and sees if it repeats. If the message still remains ten try replacing the pressure switch.
You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Please isolate the machine first and the switch will need removing from the machine.
Thanks,
E-ware
Jul 27, 2011 | Hotpoint Washing Machines
My hotpoint washer is flashing f 05 what does this mean and how can i solve it??
The error code means that the pressure switch is jammed. It does not give a solution other than calling a technician. Locate the pressure switch and tap it, it may release itself. Otherwise it will have to be replaced. The white switch below is more or less what you are looking for.
images?q=tbn:and9gctgpd2rxhiy4iqmhjtwzwti3urjnpe626kgidpkknaiof7zfzvvmg
Mar 05, 2011 | Hotpoint Washing Machines
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
1,770 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
