Question about Panasonic GigaRange KX-TG2432 Cordless Phone
PULLING THE PAPER IN WHILE FAXING OTHERWISE IT WONT WORK
HI,
ITS DIDEHKHANI FROM IRAN
I HAVE A TELEPHONE ( PANASONIC FC- 392.
I HAVE A PROBLEM WITH FAXING . WHEN WE WANT TO FAX S.TH WE FACE PROBLEM
THE PROBLEM IS THAT WE ARE FORCED INTO GUIDING THE PAPER IN WHILE WE WANT TO FAX
IF WE DO NOT DO THAT THE ACTION OF FAXING WILL NOT WORK AND GIVE US THE ERROR
PLEASE GIVE ME WHAT CAN I DO TO SOLVE THE PROBLEM
THANKS
  • gstone24 Sep 06, 2009
    do you know any one who is good at repairing our problem in Iran?
    Scholar:
  • 180 Answers
It is a dust problem on the pinch rollers which dragin and roll the paper out.
a servicing is required . please also try to load more paper as some times the more paper you load , the easier the dragging in of paper is
single paper inserting for a fax gives such problems . also quality of paper for fax must be the one recommed by the fax company ..using another quality paper will make the paper jam.
datarecoveryfactory
Posted on Sep 06, 2009
  • Arora Singh
    Arora Singh Sep 06, 2009
    i dont know any one in iran, but your local telephone help services will help you out or just type search in google search with location iran and city name .. you would definately find one soon
Keep gettomg error message 388
Hi There,
HP Support provides definitions and solutions for it's printers.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
At this site you can simply scroll down and click on the blue underlined link "388" which states,
"There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time."
"Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve."
Since you didn't state that you were having a problem sending faxes, I fear this is limit to which I can assist you. That being the case, please reserve negative feedback for HP if the solution isn't sufficient.
If the error persistes and you are not attempting to send a fax unsuccessfully, it would indicate a false error report and that your registry in your operating is a bit out of order where the printer is concerned and the best "final" solution would be to uninstall the printer from the Control Panel COMPLETELY, then hold down the WIndows logo key and press the R key. A Run window will appear. Type in %temp% and hit ENTER. Your Temp File folder's contents will appear. Left click one in that window and then hold down the CTRL key and hit the A key. All files will be selected. Hit the Delete key. Remove every file that Windows will allow and then close the window, Disconnect the printer from your computer. Then go here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Officejet+6210
Select the correct version of your 6210 (there are 3). At the next page Download the Full Version software by saving it to your Desktop. Then double-click the software installation file and follow the prompts. Do not connect your printer until the software prompts you to do so.
Ciao for Now
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Sep 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hello , \r\ni call from iran . I WANT reset the memory of fax (panasonic kx-ft67) i want clean the memory of fax .
Hi
  • Plug the power cords in, push the power buttons on and get everything up and running. Sounds simple, but lack of power is the culprit quite often.
  • Step 2Check for a phone connection in the correct input jack. Some printers with fax capability have more than one phone jack so you can hook up an answering machine or another phone "downstream" from the printer. Consult your instruction manual to determine the right connection for your printer.
  • Step 3Swap out the all-in-one printer for a working phone to find out if the problem is in the phone line coming from the wall. Once you hook up the phone, you should get a dial tone if the line is working. Remember to reconnect the all-in-one printer after you're done.
  • Step 4Open up the machine and examine the feed path for the documents that you fax. Clear any obstructions you may find. Repeat this process with the paper tray and the path that copy paper takes through the all-in-one printer.
  • Aug 08, 2010 | Panasonic Office Equipment & Supplies
    Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
    The reason for the error code:
    4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
    Solution
    Solution
    Please Click here and follow the instructions to resolve the issue.
    May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
    How to use Panasonic KX - FT 67 as an answering machine
    hello ,
    i am ali , from iran , tehran .
    if the fax in memory and paper jamed , what i do clean fax in memory & reset the memory ?
    ali_seyedein@yahoo.com
    Jan 26, 2009 | Office Equipment & Supplies
    Switching fax machine from telephone to fax
    Make sure you are NOT plugged into the port that has a picture of a telephone it.
    press
    Function 74
    set
    15
    set
    choose fax
    set
    stop
    unplug the power cord for 10 seconds.
    Dec 17, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
    Dail lock
    1 Function >>> “Change password” ENTER
    2 Display " Current password "
    3 726276642 Enter
    4 “New password”
    5 0000 ENTER
    6 EXIT
    7 Press DAIK LOCK KEY
    8 0000 ENTER
    9 UNLOCK SCUSSE
    Aug 20, 2008 | Panasonic KX-TG1033S Cordless Phone
    Panasonic KX-FM220 fax machine does not have a dial tone
    is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
    May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
    Fax wont send
    try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
    Feb 27, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
    How to not print faxes after hours
    simply go into modes Fax/telephone and select telephone mode only instead of fax/telephone mode there is really no way to set the fax to not take faxes after hours automatically as it is designed to receive telephone calls and faxes as the machine reconizes fax tone.
    the only disadvantage to doing this is you will have to change mode on a daily basis back to Fax/tel Mode during work hrs and back to telephone mode after hrs or simply uplug the phone cord going to the fax after hours
    Jan 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
    Analog to Digital Phone Service
    Nope this machine needs a dedicated analog fax line it does not work in a digital telephone system.But if you are in a very small office with a few staff. you can get your telephone people to tap off a line off the demarcation block that comes into your telephone room for your fax.
    Aug 02, 2007 | Panasonic KX-FP101 Plain Paper Thermal Fax
    Panasonic GigaRange KX-TG2432 Cordless Phone Logo
    81 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
