Question about GPS
My Navman touch screen is not responding. When it starts working it does not fail until the next time i use the device.
5 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: the touch screen does not respond
Please see this link to resolve this issue with assistance.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jun 01, 2010
mattofilms
  • 110 Answers
SOURCE: My GPS just stopped responding to touch.
can you soft or hard re-boot your GPS?
(usually by holding down the down button + menu)
Posted on Jul 02, 2009
  • 7 Answers
SOURCE: Nuvi 885 touch screen won't work
I had the same problem and Garmin's answer when I emailed them was...
"There are a few things I would suggest, first we need to updated your
system software (firmware) on the unit. To update your system software
(firmware), download the WebUpdater at www.garmin.com/webupdater.
After this program installs, your unit will need to be attached to the
computer via the USB cable. The WebUpdater will attempt to update itself
and then search for your GPS unit. The program should then recognize the
unit and you will just need to click next and follow the instructions to
update your unit. When the system?s firmware is updated, you will have
the option to update additional software that is present on your unit.
It is best to look at this list as well and check any firmware or GPS
update that are available on this page.
Once the selected updates have download to your device, please
disconnect it from the computer and allow the unit to complete start-up,
during which it will ?unpack? and install all the software updates
downloaded to it.
Secondly, you may want to try a master reset, but be advised that this
may delete your favorites. To back up your Favorites folder, you will
need to connect the nüvi to your computer with the USB cable. Open the
nüvi drive in MyComputer and then open the Garmin folder. Then open the
GPX folder and copy the CURRENT.GPX file to your desktop. If the
Favorites are deleted in the master reset, you can just go back in and
copy the CURRENT.GPX file back into the GPX folder in the nüvi drive.
To perform a master reset, with your nüvi powered off, press and hold
the lower right corner of the screen. Next, turn the power on. Continue
to hold the screen until it asks if you really want to erase all user
data. Select yes. The screen will flicker a bit and then start up like
it did when it was first turned on. Follow the directions to set time
and location. You will have to reacquire satellites by turning on your
nüvi and letting it sit somewhere in full view of the sky. This one time
acquisition may take up to 20-30 minutes. The unit may still ask if you
are indoors or if you are in Kansas. This is normal. Just answer No to
both questions. If you are on the map or satellite data screen, the
green bar at the top will now read "Locating Satellites." Make sure you
leave the nüvi out for the full 20-30 minutes. If you move it or turn it
off early the initialization process may not complete.
After completing the system software (firmware) and master reset, go out
and test the unit, if still having problems, let me know. If you have
any other questions, please email or call us at 1-800-800-1020 from
8am-6pm Central time, Monday through Friday (excluding Holidays)."
It worked for me
SOURCE: I purchased a NAVMAN S-150
I have the same problem, the s150 touch screen is pathetic, Got the same story from Strathfield Car Radio..it was normal and had it in for repairs twice when the screen went crazy with vertical lines, same fault both times. I went back to using my s50 and will sell the s150, it is a highly complex, very pretty lemon. They wont refund you or give map upgrades for inconvenience caused by their faulty product. To sum the s150 up. A truly Miserable experience. Rate it out of ten? its a minus.
Graeme
Posted on Mar 13, 2010
Reset with no disc etc
SAT NAV - RESET PROCEDURES FOR GARMIN, NAVMAN, TOM TOM
Updated 08/05/2014 05.01 PM
Reset Procedures for Garmin, Navman, Tom Tom
Garmin Master Reset NB: This will erase all way points or favourites and will restore your unit to the default factory settings.
NuviĀ® 2xx, 2x5, 5xx, 6xx, or 7xx.
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON.
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touch screen when this message displays.
  7. Touch Yes.
The device will automatically reset. Please follow the on-screen prompts on the n?vi and when completed, place your device in an area with a clear view of the sky until it acquires satellites.
NuviĀ® 8xx or 5000.
  1. Turn the device OFF (you will need to remove the battery from a nuvi 8xx).
  2. Turn the device back ON (you will need to install the battery into the nuvi 8xx).
  3. When you see a progress bar on the screen of the unit, quickly place your fingertip, or the eraser end of a pencil, in the bottom right corner of the touch screen.
  4. Hold the bottom right corner of the touch screen until a message says, "Do you really want to erase all user data?"
  5. Release the touch screen and touch Yes.
  6. The unit will now restart.
  7. Follow the onscreen prompts to set up the nuvi.
Navman S30/50/70/S80/90i.
  1. To reset your device, hold down the power button for at least 10 seconds and the device will power off.
  2. Press and hold the power button to turn the device back on.
For other models, please visit this link, select model and search for 'reset'.
TomTom
  1. Soft reset - select your model.
  2. Reinstall TomTom application.
  3. Format internal memory or memory card.
Apr 01, 2015 | Navman S30 3D Portable GPS Automobile...
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
LG KS20 touch screen not responding corecttly some times.
LG KS20 touch screen SolutionGo to settings menu - Touch celebration - click correctly touch position - u see done.
or" change your PDA ( touch screen )
Dec 15, 2011 | LG KS20 Smartphone
My Garmin 660 Nuvi touch screen will not respond I have put in the latest update, held the start button down untill the touch dot calibration shows and tryed the reset button none of this has worked, no...
This is a common problem due to certain style of touchscreen that is known to fail due to temperature. if you can not recalibrate the screen, then the touchscreen needs to be replaced. More information, including the recalibration procedure can be found here:
- Jim
Jan 18, 2011 | Garmin Nuvi 660 GPS Receiver
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
My DSI opens up but does not responds on the touch screen, left and right button and x / y button. but the camera can take pictures
One time when my dinosoar of a ds was not a dino, I left it plugged in to the wall for a few days. When I went to unplug it and play a game that required the touch screen, it seemed to not know i was touching it. That night I went and bought mario bros. partners in time and played that game (which used buttons and not the screen) until my ds died and I recharged it only for a day and the touch screen worked again.
Another time I went to someones house with 2 little kids and let them play my game. They lost my pen ( and it was a hassel finding a pen small enough to fit in the slot) and started using their fingers. We ate some super buttery popcorn and kept touching the screen with our fingers. The next day the touch screen did not work and my step dad had to use windex 3 times daily for 2 days before it would work.
Make sure you try what I tried a few times. Pretty much any problem you have with the touch screen not responding can be fixed by letting your batteries run out of juice and recharging in a maximum time of 1 day. If this fails you, make sure you are using the bottom screen. You dont know how many people I have met that kept replacing their ds and ended up finding out they were using the wrong screen. Finally, replace the screen, and buttons or just replce the ds or dsi.
Feb 03, 2010 | Nintendo DSi Black Console
I purchased a NAVMAN S-150 GPS In-Car Unit last week from ****-smith online shop. I have been testing this device for several days now. Why is it that the various touch screen buttons respond differently...
Graeme
Nov 21, 2008 | GPS
Touch screen not responding when using stylus.
Is it just possible you left the Navman mounted on the screen in hot weather whilst away from the vehicle? I made a little white jacket for mine with a heat reflecting liner.
Nov 17, 2007 | Navman ICN510 GPS Receiver
My navman icn 510 is always on SIM
Your Navman is in Demonstration mode and is demonstrating a route that you have set up. It should be flashing SIM alternately with the time taken on the route so far.
If you don't want the 'Demonstrator' to operate, you can turn it off. See your manual. If you have not got one, you can download it from the Navman site.
I only have the iCN510 and I have to go to the main Menu screen, tap 'Route Information', then Cancel Route to cancel the current demonstration.
To turn off Route Demonstrator from Main Menu icon_arrow.gif Settings icon_arrow.gif Routing icon_arrow.gif next screen icon_arrow.gif Untick 'Demonstrate Route. icon_wink.gif
_________
Oct 23, 2007 | Navman ICN510 GPS Receiver
GPS Logo
885 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
