Question about Hotpoint Ultima WF860 Front Load Washer
Changing door seal on hotpoint ultima washing machine
I really need to know how to change a rubber door seal on ultima hotpoint washing machine. complete female novice and havnt got a clue so need step by step instructions on how to do this pleeeeeeeese.
  • Anonymous Mar 29, 2014
    Hotpoint ultima leeks from bottom of the door
  • Hotpoint Master
  • 1,525 Answers
Hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Posted on Sep 06, 2009
Can I replace the rubber drum seal on my Hotpoint WF860 myself, if so where can I get one?
ebay best place very easy to change if you remove the spring on the seal on the front of the machine you can get to the clip to take of the inside you can take off the lid to get to it from the top thankyou
Jan 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
How do remove front seal on my ultima wf865
Remove top cover, unclip the control board, and unplug the lead to the board, remove screws holding board and remove same.
Remove front panel screws, remove screws holding door lock,remove clamp securing front seal ,remove seal, slide panel up and remove.
Change seal.
Re-assemble in reverse order.
Please rate my solution.
Thanks.
Jul 29, 2009 | Hotpoint Ultima WF865 Front Load Washer
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
DI 'My self' Washing Machine Door Rubber
This video will show you how to change the door seal gasket on your neff washing machine Neff W5340X0
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Neff W5340X0 Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
Sep 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do I replace the door seal on a Hotpoint WF860
unless you are really bored don't try it ..front side not bad but inside where it mounts onto outer tub can be a big black bear ..little space to work and rear band even tougher
Aug 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
873 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
