There is a part inside the TV that needs to be replaced. If the TV is
under warranty, call the manufacturer and they will arrange to have
your set repaired at little, or no cost to you.
If the TV is out of warranty, and you have the experience and you know
what you're doing, you can fix the unit yourself. Otherwise, if you've
never done anything like this type of repair before and you don't know
where to start, I suggest speaking with an experienced TV
repair-person.
If you take the TV to a repair shop for out of warranty repair, the
cost will likely be a minimum of $200 parts and labor. However,
be warned that the cost could be considerably higher.
Since some brands will pay for your repair even if you're out of warranty, you should
contact the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
If the infra red sensor connector was removed and tv shuts off then it is propably a main board issue Check for software updates first , if not then send for repaire/replace main board .
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER915B403001
Lamp (180W)
Try tv unplug,replug it an hour later.The tv will now resetting back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacenent.
After 3 1/2 hours, the battery went dead. I waited a couple of minutes, then plugged it into my computer to see if the battery would charge. It started charging. A few hours later I went back to check on it, and it showed a full battery. I disconnected it from my computer, and turned it on. It came on, but the screen just said "Low Battery". I then plugged it back into my computer, and the screen said "Rebuilding Library". I left it for about a 1/2 hour, and it was done. I unplugged it from my computer, turned it on, and it works now!! Hope this helps out everyone else who has the same problem.
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
