Question about Janome 2049LX Mechanical Sewing Machine
Janome 2003P My mahine was working fine an then wham!!!!! It seems the holder of the bobbin case is loose. I took apart the parts under the feedog and cleaned them but when I put them back the problem continued. It seems like the parts are loose in there. Bobbin case will not turn.
  • 729 Answers
SOURCE: won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
SOURCE: Janome 1 Step - model
Yes, fixed the problem this time - how, just fumbled around until it stayed put.
I find that I need Visual aids as well as the written word.
Since this was a 'cheapie' Model the 1 step, I guess there's no specific manual for it.
Many thanks for your time and effort - I know who to go to if I have other problems, thanks again.
Beryl Ross
Posted on Jan 27, 2009
  • 182 Answers
SOURCE: bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Posted on Jan 29, 2009
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble.
Posted on Mar 02, 2009
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Posted on Mar 14, 2009
  • 980 Answers
SOURCE: Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
0 characters
1 Points
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
I have a Janome Memory Craft 4900. I broke a needle while sewing in a zipper. I replaced the needle,but now the machine makes a medal scraping noise when I sew. I took off the needle plate and bobbin...
did you find the tip of the needle? Also you may have a nick in the metal where the needle hit and broke.It can catch on other parts and need to be sanded or replaced.One time I had this issue and I found the tiny broken tip under my bobbin case.
Jan 18, 2014 | Janome Sewing Machines
Janome 6500 jamming - cleaned out bobbin case - no help
Have you removed the bobbin holder and then put it back in lining up the little red markings on the right hand side? If the case has moved slightly then it will keep jamming and the bobbin thread won't clear to form a stitch. The case is held in place by a magnet and a stopper but it will dislodge if you have a bad thread jam, then it keeps happening even if you have removed all the thread because its not in position.
Check this solution for image how to remove and replace the bobbin case.
When you take out the bobbin case, carefully inspect it for any damage and burrs in the black plastic, if there are any then file them carefully out with a nail file or fine sandpaper, a burr will keep catching thread too. Or you may actually need to replace the bobbin holder if it has been pierced by the needle badly, they are about $35 or so.
You may also want to get it serviced. On my 6500 during its last service the technician added a little piece that is a Janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which is holding the bobbin holder in place better. Haven't had a major jam up since this was fitted so you may want to get this fitted on yours too.
Jul 19, 2011 | Janome Memorycraft 6500P Computerized...
The bobbin seems to be stuck and will not move...all it's doing is 'eating' the thread...what do i do? Thanks
Can you get the bobbin out of the bobbin holder? unplug the machine, then remove the needle plate, needle and pressure foot. Now can you get the bobbin out? It is possible that the bobbin holder has moved in the rotary hook, they can jump sometimes as held in by a magnet.
Check out your manual for instructions to remove the bobbin holder, it should show you how to take it out, and then clean under it, there is possibly thread caught in this area causing the malfunction.
You may find turning the fly wheel a little to turn the hook will help to free up the holder and get it out.
Here is image from my Janome 6500 manual, it should be similar for your MC.
So clean out the underneat of the bobbin holder, then reinsert it, and reassemble, thread and test. If this doens't sort the problem, then time to drive it to the Janome shop.
May 23, 2011 | Janome Memory Craft 9000 Computerized...
Hi, using a jonome finesse model 356, changed the thread on the bobbin and now its knotting up and not loose from the bottom, did i thread it incorrectly? tension is wrong now?? thanks!
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Apr 11, 2011 | Janome Sewing Machines
I have a Janome 4900Qc which has the sign Stop for Safety Purposes, this comes up really often, it has been back and been checked but no better now
Are you having thread jamming problems before you get this message?
I found that my bobbin holder which is held by magnets was being dislodged when I had a thread jam up, usually when I was trying to sew something very thick over a seam such as jeans hems.
Have you mastered removing the needle plate and the bobbin holder to clean in under it and putting this all back together again? With my 6500P, the needle had been striking the bobbin holder when it dislodged and rotated out of postion, the bobbin case had holes and damage to the plastic which was then catching the thread as the bobbin rotated making the jams happen.
Each time, I would dismantle the bobbin holder, clean everything, cut the jammed up threads, check the bobbin case and give the damaged bit a file with a nail file to make it smooth again, then put it back matching the red markings on the bobbin holder and the stopper, rethread and start over. I have bought two new bobbin cases too and taken it back to the dealer a couple of times over 5 years.
I've now learnt to not try to stitch over the thick seam intersections, I'll stop before, lift the pressure foot, move the work past the seam, then restart sewing. However, my machine was just serviced last week and it looks to me like the mechanic has added a part to hold the bobbin case in better, its like a little black lug on the left screwed into the outer housing. So perhaps Janome have addressed this issue with an aftermarket repair.
Apologies if this is telling stuff you already knew, good luck.
Mar 07, 2011 | Sewing Machines
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Won't stitch properly
Jun 25, 2008 | Janome D'cor Excel 5018
Janome 2049LX Mechanical Sewing Machine Logo
298 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
