we have a tv that once it is turned off you can turn it back on but nothing works, not the remote, front buttons, nothing! the only way to make anything work is to unplug the tv and wait a few minutes then everything works fine any suggestions?
There is a part inside the TV that needs to be replaced. If the TV is
under warranty, call the manufacturer and they will arrange to have
your set repaired at little, or no cost to you.
If the TV is out of warranty, and you have the experience and you know
what you're doing, you can fix the unit yourself. Otherwise, if you've
never done anything like this type of repair before and you don't know
where to start, I suggest speaking with an experienced TV
repair-person.
If you take the TV to a repair shop for out of warranty repair, the
cost will likely be a minimum of $200 parts and labor. However,
be warned that the cost could be considerably higher.
Since some brands will pay for your repair even if you're out of warranty, you should
contact the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i...
(More)
volume keeps cutting down. Have to use remote for the cable. It will not cut volume back up but if i keep pressing the up on the remote, a message comes up on the screen about warranty date and hours. I have no idea how to stop this. If i go to menu, the volume stays up until I close menu, then it goes right back down. I can only cut it up with the volume control button on the front of the tv.
No sound when connected to cable. No sound when disconnected from cable and the audio output cable...
(More)
No sound when connected to cable. No sound when disconnected from cable and the audio output cable is removed. (No static or cracking noise from speakers, zip.) Sound when connected to DVR player, and the sound IS coming from the speakers.
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within...
(More)
My 35 inch Tv does some quite random things. For instance it will turn of or on at will within seconds of each other. Secondly, there are times when you are trying to turn the volume up or down, and it changes "input", and will not turn off or on without the remote. When it does that the buttons on the tv are non-responsive.
