Same smart drive 601, water will stop geting in after a few seconds of
'normal' water flux...it's the first time...I think is the valve
(12v)...but could be the pump?...cause...why both valves (cold and hot)
will stop working the same day...anyway...should I change the clod
valve at least?
many thanks
Pedro
Comments:
Sep 06, 2009
- Hi, thank you very much. I've GFI, I unplugged the machine, removed the front panel, check wiring of valves (aparently ok, remove both hoses and clean filters..(hot was very dirty, cold clean)...the problem still there....
gracias
pedroSep 06, 2009
gracias
pedroSep 06, 2009
gracias
pedroSep 07, 2009
- in that case the machine will start after stop, isn't it? instead it keeps trying to fill with water with small 'shots' and then long 'trouble' beep! till I turned off.
Then, filled manually and try to drain and spin, the spin also goes in short 'tries' and then long beep...
will check better, tomorrow, the water level control.
Many thanks
