Question about HP PSC 1210 All-In-One InkJet Printer
Problem in scanning wit HP Scanjet 5590
Same problem,tried reinstalling/updating HP software,no help.- - Using an HP Scanjet 5590 with Windows Vista. I have been using the product fine and this problem just started. I am not sure if the timing is tied to a new install of TaxCut or not, but provide this as added information. The error I get is as follows:
  • 77 Answers
SOURCE: hp psc 1317 unable to use hp director scanning
Uninstall "HP Director" and replace with "HP Solution Center" New Updates (especially IE 7) make this application incompatible. Ed
Posted on Aug 07, 2007
SOURCE: Scanner component stopped communicating
well, reinstall the software and see if it will work.
Posted on Aug 16, 2007
mohanchennai
  • 490 Answers
SOURCE: Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Posted on Apr 06, 2008
SOURCE: Hp scanjet 5590 error in
I downloaded the following files from HP's website
setup_full_5590
setup_emc_5590
col10862
cit207355-hpcom-patch-v8
hpinstantshare
and followed the procedure that i found on the web at hppt://hpanswers.blogspot.com/2008/03/unexpected-internal-error-has-occurred.html
wich give full instructions on how to cleanly remove the hp software and what files you need to run to help fix the problem.
this is a fix but it is has not got my scanner working the way that it used to but it is working a lot better that it was.
Thanks
Sproket
Posted on May 01, 2008
  • 93 Answers
SOURCE: HP Solution Center reinstalls itself on every reboot.
We experience this issue if the drivers are not isnatlled properly. Once remove the USB cable from the computer if the all-in-one connected using USB and if it is network then no need to remove the ethernet cable. Now insert the CD in the computer and click on add a device option and follow the onscreen instaructions, in the miidle it will prompt to connect the USB cable then connect the USB cable and complete the process. This will resolve the issue.
Posted on May 30, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Is there any software for scanning can use with this scanjet 5590 with win 7...it seems i cant install hp photo and imaging software on my win 7 machine..help me..
Try downloading the latest software from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=377691&lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=377689
They list Win7 versions of the full software issued Dec 11, 2009, as well as just the basic drivers. However, if you installed the scanner using the generic drivers in Win7, you should be able to scan using Windows Fax and Scan or Paint. (In Paint you bring in the images as if they were on a camera.)
I hope this helps.
Feb 09, 2010 | HP Scanjet 5590 Flatbed Scanner
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
My scanjet 5590 was working ok, but suddenly stops scanning right
try reinstalling the scanner softwares and if this doesnot help do a master reset of the scanner
Jul 22, 2009 | HP Scanjet 5590 Flatbed Scanner
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
HP Scanjet 5590 nothing showing in Scan to box
go to control panel and start using the scanner from their it may work
Jan 12, 2009 | HP Scanjet 5590 Flatbed Scanner
No HP Devices have been detected. Solutions Center will now close.
It may happen if you are using HP Scanjet 5590 scnaner on windows XP. I suggest you to completely uninstlal the scanner software and then install the version 9.0 from the below link. It is the updated version for Vista but work on XP system..
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=377689&prodNameId=377691&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=sj-49436-1
Also, please connect the scanner only when it prompts to do so.
Hope it will work and 5590 scanner works with XP.
Aug 13, 2008 | HP Scanjet 5590 Flatbed Scanner
HP ScanJet 5590 ADF doesn't engage
cannot possible to install in vista using the CD of scanjet 5590
Apr 16, 2008 | HP 5590 ScanJet Flatbed Scanner
Hp director
uninstall and remove all the icons from your PC first than reinstall the driver from CD and run complete setup it works.
Feb 18, 2008 | HP 5590 ScanJet Flatbed Scanner
HP PSC 1210 All-In-One InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
