Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
When i switch on the machine the program lights are on,when i press start button it flashes on one program function and the lights above option,temp,spin,continue flashing without the machine working.
Washing Machine will not start
either your door actuator is broken or the door switch itself. look at the door and see if the latch(actuator) is broken or loose. If not order a door switch. It can be changed easy if you remove the retainer from the bellows and loosen it from the front of machine.
Hope that helps
Nov 26, 2013 | Washing Machines
CathI have a dishlex global 510 and I cant open the door does it have a child lock and if so how do I turn it off so as I can open the door
heres what it says in your manual
Follow these steps to set the Button Lock function:
1. Switch on the appliance.
2. Set a washing program.
3. Start the washing program.
4. Press Button Lock for approximately 5 seconds, or
until the Button Lock indicator light flashes.
5. Button Lock indicator light flashes for approximately
15 seconds.
6. When Button Lock function is active the indicator
light is on with a static light.
At the end of a washing program the Button Lock function
is deactivated by opening and closing the door or
switching off the appliance.
Important! It is not possible to deactivate the Button
Lock function while a washing program is in progress
if you have any further questions message me back Thanks Rick
Jun 11, 2011 | Dishwashers
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Child lock is stuck on and machine won't start
Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
Feb 01, 2011 | Asko W640
How do I set the Woods N1506 timer?
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
Need the tv code for samsung ph t4254 to program my bell remote to my tv
The codes for Samsung TVs on a Bell remote are:
505, 506, 516, 523, 526, 566,
573, 612, 627, 647, 652, 653,
654, 655, 656, 658, 659, 664,
665, 667, 669, 670, 679, 680,
704, 717, 730, 738
Try each of the above codes in turn until you find the one which works best, i.e. controls most functions. This may be limited to contolling the power, volume and channel functions. I have also pasted the programming instructions for your remote below, in case you need them.
Regards,
BElectric.
Program your remote control to operate your TV
NOTE: Before you start, locate the remote codes for the TV and write them down.
Follow these steps to program your remote control to work with your TV:
  1. Press and hold the TV button on the remote until the SAT, VCR and AUX buttons light up.
  2. Let go of the TV button. It should start to flash.
  3. While the TV button is flashing, enter one of the 3-digit codes for the TV that you wrote down earlier.
  4. After entering the 3-digit code, press the # button on the remote. If the code was entered successfully, the TV light will flash 3 times.
  5. Try to control the TV's volume and power.
  6. If the remote did not control the TV, simply repeat steps 1 to 5 with another code from the list.
If you tried all the codes provided for the manufacturer, try the following steps to find another code.
  1. Make sure the TV is on.
  2. Press and hold the TV button on the remote until the SAT, TV and VCR buttons light up.
  3. Let go of the TV button. The TV button should start to flash.
  4. Press the Power button on the remote control. The TV button will stay lit.
  5. Press the up arrow on the remote every second until the TV turns off.
  6. When the TV turns off, press the # button on the remote to lock the code. If the scan was successful, the TV light will flash 3 times.
Your remote should now be programmed to work with your TV.
Nov 23, 2010 | Televison & Video
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
26 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
