Question about Sony KP-65WS500 65" Rear Projection Television
Sony blinks seven time intervals.........
My sony projection tv.has a seven code blinking issue.I have managed to find out that it might be related to the power supply regulation and horizontal circuits exceeding 33k will place the tv in standby safety mode "Automatic High Voltage Shutdown Mode" can any of the top tv experts help in advising me how to go about and repair the necessary components needed to get the tv up and running once again or maybe a reset of some sort may be the issue at hand?
  • Sony Master
  • 5,138 Answers
I have just found this problem have you had set fixed yet if not replace relay and 47uf capacitor next to it.
Posted on Feb 19, 2008
Sony Projection Televisions - HOW TO FIX TV Red Blinking light of times between 3-second intervals and turn off
I have a Sony Bravia. Smart Television that would not turn on once in standby mode. The Red light would blink twice. I unplugged the television and reconnected it using a surge protector power supply strip. This solved my issue. From now on I'll be sure to turn the television off instead of allowing it to turn itself off.
May 01, 2014 | Televison & Video
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
TV won't turn on
Here is a link with the codes for this set and others like it:
http://www.scribd.com/doc/43529880/Sony-Blinking-Codes
Personally I would suspect the high voltage block for this set is bad.
Nov 03, 2012 | Sony Kp-Fx432M91 43" Projection Wega...
Sony KDL40EX500 shuts down and flashes a red LED 7 times. What does this mean?
This is a issue with the power supply board here is a link that shows you what this blinking light codes mean
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Sep 03, 2010 | Sony KDL40EX500 40 in. HD-Ready TV
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
My sony kp61xbr300 rear video projector tv keeps on blinking on and off why can some one help me
Please count how many times standby light blinks? There would be interval of 3 seconds between blinks.
May 02, 2009 | Sony KP-61XBR300 61" Rear Projection...
50" sony wega blinks red at intervals of 4
This is 4 time blink details for TV Sony KF-50WE610
4 times error shows that one or all 3 fans (cooling) are stop and need to be checked.
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KP-57WV600
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
