Question about Garden
4 cycle, 5hp briggs and stratton, lawn mower engine fails to start, no spark at the plug model 130202, N type magneto (i believe)
    Novelist:
  • 133 Answers
Try taking off the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs on the magneto. Also clean the end of the spark plug wire. I use fine sand paper or emery cloth.
Good luck and let me know if this helps.
thanks roundo4
Posted on Sep 06, 2009
What magneto does the 550ex Briggs and Stratton engine use
Sorry i do not understand the question, the ignition unit it a pretty standard Briggs unit, if you need a replacement unit take the model type and code of the engine ( this will be punched into the blower housing at the front just above the spark plug ) take or ring the numbers into a Briggs dealer and they will order for you,
Jun 30, 2017 | Husqvarna Garden
What do you set the timing on the camshaft/crankshaft of a Briggs & Stratton model 441777 type 0117B-1 2 cylinder?
Contact B&S through their web-site and ask them. Most B&S engines use a magneto and flywheel so there is no timing per se' as we would think of in automobile engines. Getting any engine to TDC is easy... remove the spark plug and rotate the propeller shaft by hand until the piston rises and strikes it and just begins to fall... you'll know the place where it reaches it's maximum stroke.
Oct 11, 2014 | Briggs & Stratton Garden
Why won't engine start after doing all these repairs
Make sure it is the correct spark plug with the correct gap. Then check to ensure that fuel is being delivered and is not bad
Jul 30, 2014 | Briggs & Stratton Briggs Stratton...
Why Spark on Briggs and straiten motor?
Does it have a shutoff wire on the carburetor?
Use a meter to check the coil at the magneto - if that coil reads "open" (no continuity), then it's bad & needs replacement.
Jul 26, 2014 | Garden
Dirt in fuel, how to remove gas tank
Not sure how helpful this really is, but these are the drawings and parts lists for your engine.
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=135292-1180-E1
Jun 17, 2014 | Briggs & Stratton Briggs Stratton...
Engine will not fire {no spark }
Did you sand the rust off of the flywheel? where the magneto is. And did you set it right? It has to be real close to the flywheel. The thickness of two pieces of paper. And yes the pto switch will keep it from starting. If it is ingaged it wont start. Can you hear it enganging when you connect the battery? Try turning switch on and off see if it will kick in and out. With key on
May 10, 2010 | Yard Machines 155 Torque Briggs Stratton...
Wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Nov 30, 2009 | Air Tools & Compressors
Gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Nov 07, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Apr 15, 2009 | Craftsman Garden
Garden Logo
431 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
