Question about HP PhotoSmart C4280 Laser Printer
Printer not printing what is sent to it
Instead of printing the document, the printer prints a line of code on one piece which makes no sense, then churns a continuous stream of paper through without printing anything.  it may then print another random piece of paper with code on it
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
SOURCE: The printer keeps printing pages of single line code even offline
hi i am having roughly the same problems i use cad and have not even managed to print that far yet what windows are using?
Posted on Sep 25, 2007
SOURCE: Printing Problem
Go Applications-utilities-Print Set up utility Open Print set up utility Then Go reset Print system Then go to hp folder-device utilities-hp set up assistant Run hp set up assistant to install the drivers it will fix the Problem
Posted on Oct 02, 2007
SOURCE: occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
Posted on Nov 24, 2008
noname2
  • 109 Answers
SOURCE: printer says printing document but will not print. anything
I had this same problem, and after 45 minutes with HP support, eventually managed to get it to print by turning the printer of and then holding down both arrow keys (left and right) at the same time while turning the printer back on. I held down the arrow keys until it said "Language: English" and then clicked through the prompts. It then restarted, and all was well again.
Other places mention doing this with the OK and Cancel keys, but that didn't do it for me - the arrow keys did.
Posted on May 12, 2009
Printer does not print computer documents
The queue is so choked with documents the printer gets confused and loses its sense of priority. Shut down the printer and disconnect power to clear its memory. Wait a few minutes and reconnect power. Start sending one document at a time to the printer and you should get results.
Mar 08, 2014 | Samsung Office Equipment & Supplies
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Not printing the correct text / picture
Hi..
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Sep 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Printing problems Kyocera KM 2050
try setting the driver to KPDL mode in the settings section of the driver
May 07, 2008 | Office Equipment & Supplies
Problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Feb 29, 2008 | HP DeskJet 1280 InkJet Printer
Font size
You can change the dfont size from the menu, but that setting afects the entire page of print. You different size fonts are controled from the codes sent to the printer from the software. Recreate the document, or create a document with a sample of that small print and see if the printer prints it.
Dec 04, 2007 | OKI MicroLine 420 Matrix Printer
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
Nov 18, 2007 | Canon PIXMA iP90 Mobile Printer
HP PhotoSmart C4280 Laser Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
