Question about Honeywell Heating & Cooling
I have a honeywell control unit that has a corrosion problem in the aa battery compartment, When I change the batteries every 12 months I notice it is getting worse. I put a new set of batteries in and the display goes all blank and blinks slightly and just wont work, After a while it comes good but I'm worried one day it wont work at all. I have a gas ducted heating unit and were the control unit is on the wall, There are two wires that connect into the back of the honeywell control unit that is playing up. The unit I have has week settings and weekend settings and Hold temp. Can you please help me with what unit I need to purchase to replace the not always working control unit I have. Same brand preferred.
    Scholar:
  • 48 Answers
Your problem is bad connections due to corrosion. If you would do something to correct that you wouldn't need to replace anything. Batteries ooze acid when they go bad, to counteract that you need to apply a paste of baking soda with water on a used toothbush and scrub all the funky stuff away. Paper towels are good to wipe it off with until it's dry. Take a small file or a small piece of sandpaper and dress or shine up the metal parts that contact the batteries and then spray the parts with contact cleaner from Radio Shack. Your batteries need to be changed BEFORE they purge their innards all over your good work next time - don't let it happen again.
For exact parts replacement you might find some honeywell numbers that may actually make a hit on Google. Even the most bizzare combo of Alpha and numeric gibberish in quotes will sometimes yeild pure Google gold. Other than dealing with a honeywell employee, I have no other suggestions on hunting down your part.
Posted on Sep 06, 2009
Replace battery problem. Toy will not work with new AA batteries.
Simply slot the positive terminal of the battery compartment make the positive pole which is usually wider the contact is possibly no better nor stuttering contact voltage which can cause problems.
Dec 19, 2015 | Toys
Seiko clock battery corrosion.
Use vinegar to clean out the battery compartment. It will neutralize the battery acid. Then take what is left of the springs and pull them out so they make contact with the new batteries. Sounds like you got a hold of some bad batteries.
Feb 18, 2014 | Seiko QXM265BRH Melodies in Motion...
How to change honeywell battery
Looking from the front, on top to the right is an area you can press down slightly, then move to the right. The battery compartment comes out for battery replacement. It uses AA batteries. I hope this helps you.
Oct 22, 2013 | Heating & Cooling
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats ' eHow.com http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html#ixzz17aWIl2Xt
    Dec 09, 2010 | Heating & Cooling
    Blue light on, battery won't charge, unit new 12/14/09
    rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
    Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
    Camera has failed to operate giving a "change batteries" message
    Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
    Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
    My Honeywell RTH230B temp control problems
    Yes, some thermostats rely on batteries for power to run and maintain programming
    Jul 02, 2009 | Honeywell Heating & Cooling
    Honetweel heater control unit failing
    you would have to study the wirring diagram etc but any gas heater control should work, you just have to know how to hook it up as the ignition etc is all incorporated in the control
    May 03, 2009 | Honeywell Programmable Thermostat Heater
    Cobra Model HH35 radio dummy batteries
    Normal AA batteries are 1.5 Volts each. The battery compartment on the HH35 holds 10 Batteries. If regular batteries are used they must be configured to a 12 Volt output. Thus the Dummy (Blank) is used to Make 8 X 1.5V=12 Volts.
    If you use NiMH or Nicd which are rated at 1.2 Volts 10 X 1.2 =12 Volts.
    Nov 21, 2007 | Radio Communications
    Battery Issue
    This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
    Thank you and warm wished for the new year!
    Mary
    Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
    Heating & Cooling Logo
    190 people viewed this question
    Top Honeywell Heating & Cooling Experts
    Bill Long
    Paul Carew
    vance jones
    Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
