Question about Epson Stylus Photo R300 InkJet Printer
Black and cyan cartridge will not print . these are new cartridges.
    Sergeant:
  • 244 Answers
If they have tape 'protective seals' make sure they're removed. also be sure they're seated properly. run test print on the printer. see if these suggestions help.
Posted on Sep 06, 2009
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Will PIXMA MP640 print with an empty cartridge
No, it will not. I have this printer and last week I ran out of cyan. Even though i only wanted to print black and white documents the printer would not print anything until I replaced the cyan cartridge.
Jun 25, 2010 | Canon Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Magenta and yellow wont print. new cartridges,black and cyan ok cleaned heads
All new cartridges loaded but no black printing. I changed the black cartridge with a second new one but still no black text printing !
Is this Epson 5800 printer a wtite off at this stage ?
John
Dec 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
My cyan cartridge shows as empty. My black
No. You need all the cartridges installed with functioning chips for your printer to work. The reason why you need all the colors when all you print is black is because a small amount of color prints when you print black. The manufacturers want to make up their R&D costs on the printers by selling lots of expensive ink.
Nov 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus Photo R300 InkJet Printer Logo
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
