Question about Gateway Computers & Internet
I have a gateway w340ua lapetop the screen dont turn on
  • Gateway Master
  • 32,281 Answers
Does the laptop appear to bootup?
Does the hard disk appear to be spinning and the hard disk LED light flashing?
If so the laptop maybe booting up and the LCD screen maybe faulty. If so follow these instructions to determine the screen fault :-
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 06, 2009
    Problem Solver:
  • 6 Answers
Have to do a reflow with flux and industrial heat gun, cover all the mother board with foil not the video chip, and carefully heat around chip like for 30 to 35 second, it works!!! That is the most common problem among laptops. Do that they have poor dissipation or clogged coolers, although you have to be very careful with this procedure...
Posted on Mar 02, 2011
    Problem Solver:
  • 6 Answers
Disassemble the laptop & remove all the chips (ram, processor, cmos battery, ect.) and stickers from the motherboard. Lay the board just above the eye of a stove on top of 3 shot glasses with the gpu and processor socket facing up. Turn on the stove and heat to 420 degrees varying temps between 420-450 for 6 or 7 minutes. Make sure you have a temp meter close by to keep things in check. The board will be very hot and fragile. After the 6 minutes of cooking, turn off the stove and let the board cool for 20 minutes or so. Reassemble laptop. Turn on and enjoy!
Posted on Aug 04, 2010
My gateway w340ua has a black screen how can i test it with an external screen.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 04, 2011 | Gateway Computers & Internet
Gateway Laptop W340UA black screen
  1. take out the memory
  2. turn on again without memory (you should hear long beep sound) and turn it off again
  3. clean memory using eraser (better if you have spare memory to replace it)
  4. now try again
  5. if not working, checks whether the work properly? and clean the fan from dust. and try to switch it on again.
I look forward to hearing further.
Dec 14, 2009 | Gateway Computers & Internet
Gateway W340UA Black screen - does not boot
Yep it's probably the graphic card that's failed
Oct 16, 2009 | Gateway Computers & Internet
Help!!!- Gateway w340ua. Brightness flickers and comp shuts off
sounds like a power probelm
check the pin in the dc jack where you plug the adapter in, if this pin is loose just a little
it could be that yoru going from battery power to ac power , for that reason your screen would flash and you would shut off now and then
Jul 22, 2009 | Computers & Internet
Gateway W340UA No Sound After Installing XP
Here is NVIDA web site whwere you can automatically download drivers for your product.
http://www.nvidia.com/Download/index.aspx? lang=en-us
Gateway also has an automatic download site for drivers, based upon your OS.:
http://support.gateway.com/support/drivers/search.asp?ref=nofind&ct=fn&param=gtwupd.exe
Dec 21, 2008 | Computers & Internet
I Don't Have Sound On My Gateway W340UA
I Want To Say BIG THANK YOU to Smithbrother
I
Instal the" GWA assistant setup",from the weebsite below, then download drivers directly for the gateway site.
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=11334&os=10406&type=10100
Gateway laptop
you and your computer need to tite lohdra ok
i thanig your problem sovel
May 05, 2008 | Computers & Internet
Computers & Internet Logo
2,042 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
