Question about Hotpoint Washing Machines
Hotpoint WF321 Washing Machine On connecting the machine to the mains electricity supply the following lights start to flash. The on/off switch does not switch off these lights. Wash Enhance Flashing Reduced Creases Flashing Rinse Hold Flashing Mini Load Flashing Final Spin Flashing On/Off Light Flashing The machine does not do anything else Please advise if this is indicating a specific error / code.
  • 2 more comments
  • patjlear Sep 06, 2009
    Hi there...the main drum motor and the pump motor are free to rotate...there are at least 2 circuit boards which could be faulty.
    The flashing light sequence is a fault diagnostic ....I require this interpreting to determine the fault
    Do you have a list of diagnostic codes?
    I have the manual ..but it does'nt cover all of the fault codes ....thanks anyway
    Good call...have connected to another socket outlet ....at first all lights flashed...and then the stabilised to "power on"
    I have selected a programme and the machine is starting to cycle the this
    On previous occasions the machine has gone through a phase of all the lights flashing when first switched on .....does this indicate that there is a fault?
    Yes I have found the answers that Im looking for
    Many thanks
  • 430 Answers
I think the motor is stuck. Replace it. The another thing that can be fault is the CB.
Posted on Sep 06, 2009
  • 1 more comment
  • Nandini Dhar
    Nandini Dhar Sep 06, 2009
    http://www.manualsmania.com/store/order....
    Sir , you can go there and get the manual. It contains Programmes, Installation, User manual, Troubleshooting guide. You can buy it at just 1.99 $.
  • Nandini Dhar
    Sir, I now suspect the power supply is not up to mark. Please check the electric point with a multimeter.
  • Nandini Dhar
    I think something is surely a fault in the control boards. They can't keep on the right process to make the machine working.
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
I have a hotpoint aquarius WF321 and all the lights on the control panel are constantly flashing which means I can't even turn it off or do anything with the machine. On the odd occasion that it does stop...
i too have the same problem, i am going to buy a new PCB.
which is the electronic circuit board. about 75 quid.
cheaper than a new machine if it works
Dec 04, 2010 | Hotpoint Washing Machines
Hotpoint W321 flashing lights - washing machine
I have the same machine and it's the 2 solenoids for the cold water inlet at the back. I took the top cover off with 2 screws at the back and the 2 solenoids are connected by 2 screws. I dont know the price as i cleaned mine by flushing fresh water through and the spraying a little wd40 into both parts and it works fine now or just buy new part it's easy to fit but make sure always the mains is disconnected.
May 04, 2010 | Washing Machines
Hotpoint aquarius wf321 when turn on all red light fleshing Problem nothing happenes.
half way through the cycle all the lights start flashing then it makes a loud noise when spinning
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi i have a wf321 aquarius. When i switch it on
looks like the main pcb is failing you.. checke all connections to be on the safe side( with the power off & plug out of course).
Thanks
Dec 18, 2009 | Hotpoint Washing Machines
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
298 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
