Question about Apple iPod shuffle MP3 Player
Lwhen play led flashesgreen and then yellow
Will not play having problems keeping a charge yellow light flashes when i press play button it will flash green then urn to yellow and nothing can be heard
    President:
  • 392 Answers
Try restoring it with itunes
Posted on Sep 06, 2009
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Dec 24, 2009 | Apple iPod shuffle MP3 Player
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Since last week the answer ''on'' light just keeps flashing and it doesn't works when somebody calls me. I have tried unplugging and replugging but it just keeps flashing.
Turning the answering
system on/off
Press {ANSWER ON} to turn on/off the
answering system.
LWhen the answering system is turned
on, the ANSWER ON indicator lights.
off, the ANSWER ON indicator turns
off.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Answer on” or “Answer
off“i {OK} i {OFF}
Hi again. The reason that your are experiencing this issue is because of you answering options. Here are some instructions on how to turn this feature off. thx for using fix ya:) (we were previously dissconnected)
Feb 19, 2009 | Panasonic KX-TG1032S Phone
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
How to set up yobo controllers for ps3
I just bought a used one today and took me a little while to get it to work. Plug the USB receiver in and turn on the PS3. Press the Mode button and the lights will flash repeatedly at a fast rate (it's searching for the receiver). When it finds the USB receiver, the lights will still flash, but slower than before. When they're doing this, press the mode button again, and that should be all that you have to do. You can also plug the receiver in USB slot one, the charge cable in slot 2, and do the steps to set it up to make it work while charging. (I tried taking the receiver out while charging, and the lights started flashing again so I guess the USB receiver has to be in at all times)
Jan 11, 2009 | YOBO FC Game Console
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Pairing s9 headphones w/krzr
OK I managed to get my head set to work. Make sure the unit is charged, press and hold both the 'ON' button (on neck piece) and the "PLAY/PAUSE' button on the right earpiece. Keep holding then the LED should flash Blue three times THEN flash alternate RED and BLUE. You should then be able to Pair the Device. Good luck
Oct 21, 2007 | Motorola Radio Communications
Apple iPod shuffle MP3 Player Logo
51 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
