Question about Tomtom GPS
My TomTom screen is lit but cannot switch on - Tomtom GPS
  • 3,153 Answers
A little more information may have been useful but lets see if one of the common fixes works for you.
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
If this works great ! But if not try let me have a Little more info and lets see what we can do for you.
Posted on Sep 06, 2009
Can u help my tomtom has a problem?
My TomTom 3rd g is acting up. It is not making a connection. The green bar run quickly and than the screen shows no hands / touch available. It will not go any further than that. It keeps running the same thing over and over again.
P.S. I tried resetting but it just shows that screen
Feb 10, 2010 | Tomtom ONE 3rd Edition GPS
TomTom Go 910
my tom tom one xl has been used 3 times... tried to use it today...pushed on button...start screen on,,a few seconds later the satchel w/the gps and it turns off
Jun 09, 2009 | Tomtom ONE GPS Receiver
I have a tomtom one 2nd edition. It is frozen on.
Easy, simple take a pen and press the reset on the bottom of the Tomtom, just like any other electronic device.
Dec 30, 2008 | Tomtom ONE GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Tomtom one not poweringup
Lofty same just happened to me, following great deal of searching, my conclusion is that over voltage has fried regulator chip in tomtom, the reason you have green light is because at different part of power board. Approx repair cost if damage is not too bad (50% cannot be repaired) is £70.
TOMTOM will have a look for nothing, and give you a quote, if don;t want to proceed they will send it back for free also.
Good luck.
Mar 17, 2008 | Tomtom ONE GPS Receiver
CANNOT RECHARGE TOMTOM
If you have the green light lit on top of the tomtom but it won't switch on , then you have a condition commonly known as "the Green Light Syndrome". Most likely cause is blown components inside the tomtom that regulate voltage. The reason they blow is usually due to user connecting incorrect charger ( such as a 12v one for a phone ) or sometimes the tomtom charger goes faulty and instead of ouputting 5 voltas it outputs 12 volts and damages the tomtom inside. the parts are not easily repalced and require a specialist repair centre that has good experience of repairing tomtoms. You cannot repair it yourself using a normal soldering iron. Good luck.
Feb 16, 2008 | Tomtom One Europe v2 GPS Receiver
Screen stays lit and is blank
Try a reset. It worked for me with the same problem.
Aug 15, 2007 | Tomtom GO 910 GPS Receiver
GPS Logo
29 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
