Question about Whirlpool Washing Machines
Whirlpool A+A 5kg/1000 AWO/D4305 clean pipe light has come on what shall i do
  • 430 Answers
I think you are wnting to tell the message is " clean pump ". There is no such " clean pipe ". Sir, please reply me for this matter.
Posted on Sep 06, 2009
  • Nandini Dhar
    Nandini Dhar Sep 06, 2009
    Open the unit up. Not any big job, I promise. Here is step by step:
    1) Turn off the water valve going to the machine
    2) Unplug it from the wall
    3) Make sure you leave the water to cool down for a while if stil hot.
    4) Once you are sure of above is done, move the machine to some where where you will be able to tip it forward to its front face down and the water can drain out without making your kitchen into a swamp!
    5) Open the filter to let the water out
    6) Now lay it onto the ground face down (maybe use old pilows to spare any possible damage under it)
    7) When you look in the base, it will have a black rubber tube going from the base of the wash drum to the filter. It is held on by metal fixing clasps.
    8) Take the one off at the drum by squeezing it with either your fingers or gently by a large pliers.
    9) Once removed there will be a ping pong ball in the rubber tube, leave it and clear everything else.
    10) Clear the hole from the drum of any blockage.
    11) Check the tube to make sure it flows clear by pouring water through it and seeing if it runs out of filter (as it should still be open from earlier).
    12) If not do the same clearance to the filter end of the rubber tube.
    13) BE SURE AND REATTACH THIS RUBBER TUBE FIRMLY AND CAREFULLY. AS IF YOU DONT WATER WILL GO EVERYWHERE.
    14) Put the machine up right back into position reattaching the water pipe (and turning water back on) and drain pipe.
    15) Pour liter or so of water into the washing powder opening and plug in once you are sure all pipes are correctly back.
  • Nandini Dhar
    Sir, tried my steps. Please reply me.
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
AWO/D4305 Does not spin
its not hard to put in yourself if you lay it on back and work from bottom..... est. motor cost is 130 to 150 dollars
Aug 06, 2009 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
