Question about Dell Latitude D600 Notebook
Sound of fan increased in my inspiron1545 laptop
Fan makes loud noice when it rotates in my laptop...
  • 279 Answers
If you have the unit apert to clean the fan, on one side of it you will find a paper label in the middle gently remove the label and it will expose the bearing. 1 drop of very light oil (sewing machine or similar), and leave for 5 mins so that it can soak into the bearing assembly. replace label and refit fan.
You will still need a new fan but it may last anouther 6-12 month.
Posted on Apr 14, 2012
  • Dell Master
  • 32,281 Answers
The fan most likely has a fauly/worn bearing or is clogged with dust.
Try cleaning and removing the dust from the fan anf heatsink assembly.
If this doesn't work then replace the fan.
Posted on Sep 06, 2009
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
GE Dishwasher - loud rumbling/growling noice!
If I am not mistaken this dishwasher has a Clean out at the bottom of the machine that can open .This is here to catch stuff like broken glass and things like that. It has a little fan like blades that act to chop up food that is to big to go down the outlet hose. also look under the machine if you can ,but in most cases you must remove 4 screws to get the bottom kick plate off, Also check all the spinning arms to make sure they are turning correctly. hope this helps
May 02, 2012 | GE Dishwashers
I have a HPDV9000 Laptop and it is making a terrible loud noice, very annoying. Starts when turned on. What can it be. Thank you.
More than likely it's one of the cooling fans. They spin at relatively high RPM and if they're damaged they can emit a loud whirring or screeching noise. If it's a clicking noise then it could be your hard drive failing.
May 04, 2011 | Computers & Internet
My dell laptop inspiron 1420 is produicing noice from the internal fan
most of the time this noise of the fan should normal but incase it is really loud please make sure no wire or anything tangled up with the fan...if not have if replaced
Oct 01, 2010 | Dell Inspiron 1525 Laptop
The freezer fan makes a very loud noise
it probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Apr 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
I can hear a loud rumbling sound when i turn my laptop on.
Sounds like one of three things... A CD not seated correctly... 2 internal Fan maybe bad or 3 your Hard Drive could be failing.
Make sure you have a back up... use a thumb drive i you can... faster.
If it is the HD then the noice would change as you are doing tasks. As its working it will change tunes.
A Fan may stop and start... there is a fan vent at the side or bottom of the laptop... see if it is coming from there.
Jan 24, 2010 | Computers & Internet
My laptop is overheating and it is very loud when i turn it on and when it gets too hot it turns off
loud in the sense if ure talking about a loud noice contant beep noice it is your mic. go to sound setting s in control panel go to advanced and mute your mic. that shud take care of the loud noice. as of over heating it must ve been the coolant. u probably shud get it fixed or ull lose ur internal hardware. battery mit also be the problem
Dec 09, 2009 | Computers & Internet
Charger makes loud whining noice
they have a cpu fan in it, and unlucky for you you cant buy anthother part, you either get a new one, or try sparaying some WD-40
May 02, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Dell Latitude D600 Notebook Logo
75 people viewed this question
Alun Cox
